Author Topic: These small rim studs that grip the tire  (Read 4658 times)
Offline eric318
  • XR500 only
    • XR500 Only
« on: December 16, 2012, 08:49:58 am »
Hello all,
I am about to take a nice old Hallman Sun rim to be re-anodized (gold).
I had to remove the little pointy steel stud that were pressed at regular intervals on the inside of the rim edge. See photo.
Some of them are quite damaged and I wonder where to get a full set of them.
I don't even know what they would normally be called, so wasted some time on Google.com.
Any pointers?
Thank you,
E
I do only XR500 79-84, preferably tricked
https://www.facebook.com/groups/207461083953032/
maico police
Re: These small rim studs that grip the tire
« Reply #1 on: December 16, 2012, 09:19:14 am »
Gary Bailey talks about them in his book "How to win motocross". I've always been intruiged by them as they'd make for a more balanced wheel than one with rim-locks.
He just used to used some big self-tappers just long enough to not penetrate the inside wall of the tyre.
Going to give it a go myself soon.  :)
Offline Canam370
« Reply #2 on: December 16, 2012, 09:57:16 am »
I've always known them as rim pins. Sen a few rims where the pins are removed from one side to make tyre removal quicker on the trail.
Offline NSR
  • Sunshine Coast
« Reply #3 on: December 16, 2012, 10:34:01 am »
I used to use self tappers only on one side.  I would think you would still be able to buy Rim Pins.  Contact Ballards.
Just a thought do they use these when they run Bib Mousses?
The Swvm though the tree's! http://youtu.be/4h6BbasT16I
Metalink Conondale vinduro sprint. May 19/20 2018
www.metalink.net.au  Bike trailers & Canopies
Offline huskibul
« Reply #4 on: December 16, 2012, 10:56:08 am »
   Imo the pins can be a pain when in a hurry trying to set the bead right ! bultaco/akront used screw's on most mudless rims and were easy ,cant remember seeing any problems with them ! maybe bully got the idea off bailey when he rode  them or vice-versa  :)
« Reply #5 on: December 16, 2012, 11:20:30 am »
Yeh I had a bike in the 80's with 'rim pins'; never had a tyre slip.  I've been thinking about using self-tappers in all my dirtbikes; just getting up the courage to drill the rims lol
Offline TeeBone
« Reply #6 on: December 16, 2012, 12:18:45 pm »
With a Mousse, there is NO need to prevent the tyre from slipping (not that they do) as there is NO valve to rip out. I have always known them as RIM PINS too.
Offline KB171
« Reply #7 on: December 16, 2012, 12:40:07 pm »
Peter Shone -  Bultaco Parts in Vic sells them about $20 per set, you need a 4.5mm x .75 tap to suit the threads.
Cheers KB
That size was for the front rim, rear pins are a bit bigger,
« Last Edit: December 16, 2012, 12:46:57 pm by KB171 »
Offline David Lahey
« Reply #8 on: December 16, 2012, 02:12:25 pm »
The Bultaco screws are OK but I wouldn't recommend using standard self-tappers because they are too pointy and sharp and rip the bead to shreds within seconds of getting a flat. Concurrently, the steel wire from the bead winds up around the axle/sprocket and things come to a stop.
My advice comes from first hand experience in 1977 or 78. It was somewhere near the Glasshouse mountains. After getting the remains of the tyre off and unwinding all the wire, I rode to the next checkpoint very carefully on the rim. I remember the day well also because Phil Eldridge stopped and asked did I need any help and I was quite impressed to see someone racing with a prosthetic leg.
previous pseudonym feetupfun
« Reply #9 on: December 16, 2012, 03:46:55 pm »
That's handy to know; thanks.  I will grind/round-off the self-tappers.
Offline eric318
  • XR500 only
    • XR500 Only
« Reply #10 on: December 17, 2012, 04:07:05 pm »
Thank you all,
I found them where I looked for them without knowing what they were called:
http://www.buchananspokes.net/categories/miscellaneous_tools.asp
