Author Topic: 495 bottom end  (Read 4103 times)
495 bottom end
« on: December 15, 2012, 02:56:03 pm »
Need desperate 495 bottom end or even borrow one for bit.
Offline Moto
Re: 495 bottom end
« Reply #1 on: December 15, 2012, 10:31:55 pm »
Is that a reed valve set of cases or the piston port engine?
Re: 495 bottom end
« Reply #2 on: December 16, 2012, 08:33:57 am »
It would be the reed valve 84 model I have a good barrel and head new piston etc
Offline jurado
Re: 495 bottom end
« Reply #3 on: January 18, 2013, 06:22:33 pm »
Why don“t you install a new sleeve into your cylinder and leave it at 92.25 mm bore for standard piston?: Probably it will be cheaper and easier to get than finding a usable cylinder.
I am about porting mine. Seems lot room to improve it.
Offline oz555ktm
Re: 495 bottom end
« Reply #4 on: January 18, 2013, 09:29:11 pm »
  Waring . yes it true to look at the ports look dirty and mist match!!!!!!!!!!!
  Just match porting wiil do a lot and will chang the way the power come ..
   But I can not ride to the max or 3/4 of the 52 Hp so why do you need more ????
Offline jurado
Re: 495 bottom end
« Reply #6 on: February 13, 2013, 05:40:32 pm »
I need a gearbox/crank or even a new conrod
