Author Topic: 2K paint in a spray can....it does exist!  (Read 1967 times)
Re: 2K paint in a spray can....it does exist!
« Reply #1 on: December 10, 2012, 03:01:59 am »
well if it is 2 pak and your using it wear a double cartridge mask with the right cartridges for that type of paint coz 2 pak has alot of cancer causeing shit in it ;)
Offline Andrew L
« Reply #2 on: December 10, 2012, 08:28:22 am »
If they are just a base coat requiring a clear over the top they are not required to be mixed with a hardener so are a single pak that is 2 pak compatible for top coat,  the clear coat or top color coat in 2 paks require a hardener to make them dry.
