Author Topic: RM 125 cylinder  (Read 3110 times)
Offline Nipper
RM 125 cylinder
« on: November 30, 2012, 04:59:32 pm »
I have a rm 125 b cylinder that is now at 56mm this is 2mm over the original and it is not looking pretty down there.
I am thinking of getting it resleeved so as to start with a standard piston. Is this the best way to go ,or should I just look for another barrel? Any thoughts .Cheers Nipper
Offline Canam370
Re: RM 125 cylinder
« Reply #2 on: November 30, 2012, 05:45:51 pm »
I have a 125B engine with electrics I'll part with- no piston but the bore looks OK and the bore measures 54mm. PM if interested for details.
Re: RM 125 cylinder
« Reply #3 on: November 30, 2012, 05:53:43 pm »
I'll swoop on it if he is not interested.
Re: RM 125 cylinder
« Reply #4 on: November 30, 2012, 07:53:12 pm »
You can Nicasil over cast iron would cost the same as the NOS cylinder.
Re: RM 125 cylinder
« Reply #5 on: November 30, 2012, 10:34:01 pm »
Use an Elsinore piston. 56-58mm should be plenty of cylinder to bore that far.. You'll have to do something about the increased compression unless you can get some better then pump fuel.
Offline Bamford#69
Re: RM 125 cylinder
« Reply #6 on: December 01, 2012, 12:42:28 pm »
Hi,
If  you use an Elsinore piston 56-58mm, remember GCR rule 12.4.5.1 page 92, Engine Capacity Tolerances, Classic Motocross 5% permitted excess (bore/engine size).
Re: RM 125 cylinder
« Reply #7 on: December 01, 2012, 05:39:54 pm »
;D ;D ;D ::)
« Last Edit: December 01, 2012, 05:42:06 pm by firko »
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: RM 125 cylinder
« Reply #8 on: December 01, 2012, 06:07:25 pm »
;D ;D ;D ::)
what he said ;D ;D ;D ::)
"flat bickie"
Offline Nipper
Re: RM 125 cylinder
« Reply #9 on: December 02, 2012, 02:03:34 pm »
Thanks guys for your input with the rm cylinder it has been great. Canam370 has come to the rescue with a spare parts motor to help fix the situation. Cheers Nipper.
