Author Topic: HL500 ID  (Read 27140 times)
Offline Tahitian_Red
  • Mugen ME480
HL500 ID
« on: November 27, 2012, 02:18:13 pm »
How do you ID the three different HL500 builds (Hallman-Lundin,NVT and Pro-Fab)?
The "Factory Novice"
California, USA
Re: HL500 ID
« Reply #1 on: November 27, 2012, 03:41:10 pm »
Have you spotted one TR?
I believe Profab made the frames for Hallman so as far as I am aware there were only 2 originals.
They are very similar but can be picked apart by…
Footpegs –
Profab had splined mounts on the frame.
NVT had 2 tapped bosses welded to the lower tube.
Steering stops –
Profab had 2 tubes sticking out just like Husky’s did.
NVT had 2 bits of flat.
And GMC frames all have GMCHL### stamped on the front of the headstock and on top of the swingarm crosspiece and are replica’s of the NVT frames.
Also Frames for the Yamaha engine had a vertical square box backbone behind the engine.
Frames without this will be for Suzuki or Honda engines and both Profab and Curtis made them for these engines. Curtis frames being styled very closely on the NVT frame.
Offline paul
Re: HL500 ID
« Reply #2 on: November 27, 2012, 04:13:18 pm »
Offline paul
Re: HL500 ID
« Reply #3 on: November 27, 2012, 04:18:27 pm »
  • Mugen ME480
Re: HL500 ID
« Reply #4 on: November 27, 2012, 06:16:48 pm »
GMC,
So, I would guess this is an early ProFab with Marzocchi forks?  The front motor mount had me wondering, but it has the boxed tube oil tank.
California, USA
Re: HL500 ID
« Reply #5 on: November 27, 2012, 09:13:10 pm »
That looks every bit like a Profab.
Tube steering stops.
Flat bar around the headstock. The head gussets will only have a small part that welds to the rear of the headstock.
NVT frames didn’t have the flat bar but the head gussets wrapped around to the front side of the headstock.
Profab frames had a couple of different versions of swingarms.
The brochure even had 2 types on it.
The one on that bike is the most common, it also looks very similar to the 79 NVT arm
78 NVT’s had the ‘banana’ style arm
It looks like it has the right engine mount plates in alloy, it just has some strange black ones on top!!!
Actually the black plates might be the top engine plates, just bolted with the others for safekeeping.
It’s hard to make out the footpegs in that view.
Is it just me or is it the more knowledge you gain on the details of old bikes the more pathetic you feel ::) :D
Offline ola_martin
Re: HL500 ID
« Reply #6 on: November 27, 2012, 11:03:12 pm »
Not just you ::)
Offline SON
Re: HL500 ID
« Reply #7 on: November 27, 2012, 11:09:51 pm »
I have not seen a bare Hallman XR/XL Frame,
Does anyone have a photo?
Offline flower pot racing
Re: HL500 ID
« Reply #8 on: November 28, 2012, 04:16:47 am »
Not just you ::)
mmm, yes, I know what you mean.  I am hoping to get an new anorach for Christmas...!!!
Offline Graeme M
  • Administrator
  • Canberra, Australia
Re: HL500 ID
« Reply #9 on: November 28, 2012, 06:24:08 am »
Geoff I think you are right. Having owned a Profab bike that frame is identical as far as I can see in the photos. The engine plates would appear to be the correct alloy front plates and the head stays attached to that.
maico police
Re: HL500 ID
« Reply #10 on: November 28, 2012, 07:28:16 am »
Just as well you sold it Paul.
It would have cost a fortune in swingarm pivot sliders to run (and blocks of wood to stand on when sittin' on it)..... ???
TM BILL
Re: HL500 ID
« Reply #11 on: November 28, 2012, 07:51:43 am »
Wonder how Sten Lundin and Torsten Hallman would feel about all these jacked up wonders  ???
Can only imagine they would feel like Leonardo De Vinci would feel about these
Offline paul
Re: HL500 ID
« Reply #12 on: November 28, 2012, 08:26:43 am »
your still dirty that the maico in the back ground was not for you and i seem to remember that big bores werent for you either! considering you sold the lot after the famous wonthaggie ride in a ambulance incedent
maico police
Re: HL500 ID
« Reply #13 on: November 28, 2012, 08:52:10 am »
I was bidding on a 440 just like that one once...... :-\
Offline paul
Re: HL500 ID
« Reply #14 on: November 28, 2012, 08:54:04 am »
i know you were but it take a special type off person to own one
