Author Topic: White Brothers DR400T  (Read 106045 times)
Offline Marc.com
« on: November 27, 2012, 07:43:37 am »
Hi does anyone have the original article on the White Brothers hotrod DR400T on PDF.
Just bought my DR400 White Bros swingarm to put under the Xmas tree.  ;D
Offline suzuki59
  • Kiwi VMX
Re: White Brothers DR400T
« Reply #1 on: November 27, 2012, 06:38:00 pm »
Good luck with that mate,it will need some serious porting to carry you at full steam.
Ps I think I will have a magazine with an article on that beast,come to Taupo and I will give it to you.
Or are you waxing your bikini line?
Offline cloggy
« Reply #2 on: November 27, 2012, 09:15:30 pm »
 I had the article but the magazine has gone missing. Dirt Bike put RM38s on the front, bored out the triples, shoved on the swing arm and   16.5" shocks, put a 36mm mikuni on + WB cam with [protec springs?],
 ground off the intake weir and put a WB420 high comp piston in , junked the exhaust  and installed a megaphone but I can't remember what they did with the airbox, I think they dumped it for a K&N.[previously they'd junked the snorkel] That was about it. They did say it was an excellent playbike as standard and were very happy with the subsequent bolt on mods. They ran down CCMs with it.
 Here's some road race tuning info
http://ozvmx.com/community/index.php?topic=4582.15
Bottom of the page
« Last Edit: November 27, 2012, 09:20:49 pm by cloggy »
Offline SON
« Reply #3 on: November 27, 2012, 11:20:34 pm »
Stroker crank is the way to go for the SP/DR engine,
No need for cams or big bore,
Carb and Exhaust are obvious,
Dellorto pumper worked good on them,
Supertrapp 4" balanced it all,
Offline Marc.com
« Reply #4 on: November 28, 2012, 06:24:01 am »
Yeah I was planning on a little man scaping that weekend.
Thanks Cloggy I was reading in the wong area, but that Hallman thread gives me some ideas. I am just doing a DR400T with WB swinger and Simons, all I have to do now is pulverise the old swingarm out that has fused in a rigid position.
Offline cloggy
« Reply #5 on: November 28, 2012, 08:41:27 am »
 I've got one DR set up with later single shock 38s and emulators. With hindsight I would go for the early 38s and keep the DR front wheel [though you can use sleeves to use the early wheel with later fork]
 I run the first RM 1978 ally swing arm, which didn't need much altering, 16.5 Falcons and a ProTec mild cam and the 370 carb. I'd use a bigger carb for motocross. One problem is working out what spring rate for the cam as no one stocks springs and keepers. I think R&D have the springs but no keepers. In all honesty the main gains are unplugging the intake and exhaust, the standard cam is good.
 SON is right, it really needs stroking. It was in production for such a short time that it didn't get much attention, but it's a really simple  and tough engine, simpler than an XT, and the frame is RM derived. Handles well except at low speed when the front end wanders. It's not that good at really high speeds, moves around a bit compared with a KLX, but is ok on a motocross track, it's intuitively predictable. I use mine for welsh forest rallies where you get everything from wet steep mud and scree to flat out grade roads. I keep the carb/airbox to keep it a submarine. It's not uncommon to get 3 or 4 " of rain in a weekend.
 I had problems getting heavy enough fork springs and the 400 carb not working as soon as I opened up the airbox intake. If you've got the WB 36 mikuni carb already I'd love to know the specs. Tom White sent them to me some 30 years ago and I've lost them.
 RaceTech do the fork springs
       http://www.racetech.com/page/title/FRSP-RT%20Fork%20Spring%20List
 though I picked up a heavy duty Maico set.
« Last Edit: November 28, 2012, 08:48:54 am by cloggy »
GT43
« Reply #6 on: November 30, 2012, 02:38:26 pm »
« Last Edit: November 30, 2012, 04:12:20 pm by GT43 »
GT43
« Reply #7 on: November 30, 2012, 02:48:14 pm »
Geez, I posted the images above at a resolution of "1200 x 1566".
This forum automatically shrunk them down to a whopping "784 x 1024" !!
Just realised it is Photobucket that changes res. Couldnt find the res settings, so switched back to the old interface and found them.
Forum still shrinks them. But if you "Save" images to your computer, they will be higher res and easier to read. :)
« Last Edit: November 30, 2012, 04:16:16 pm by GT43 »
Offline smed
« Reply #8 on: November 30, 2012, 03:37:16 pm »
What did Gally ride in that CMC race a HL? it says he came fifth :)
GT43
« Reply #9 on: November 30, 2012, 03:49:29 pm »
Wish I knew Smed.
But if I find out I'll get back.
« Reply #10 on: November 30, 2012, 06:54:38 pm »
How sexy is the mega phone/rear guard number plate combo :-*
Offline suzuki59
  • Kiwi VMX
« Reply #11 on: November 30, 2012, 08:21:22 pm »
Hey Marc dot com,it's probably wise you get your mechanic to remove the swing arm given your agricultural mechanical skills.
Offline Marc.com
« Reply #12 on: December 03, 2012, 11:05:56 am »
You forget I do have some experience working on farm machinery  ;)
Hey I heard you got drunk in Taupo and tried to give Bill a love bite  ;)
Offline Tahitian_Red
  • Mugen ME480
« Reply #13 on: December 03, 2012, 11:42:26 am »
Yes HL.  I posted some pics a few years ago.
The "Factory Novice"
California, USA
Offline bazza
« Reply #14 on: December 03, 2012, 02:35:30 pm »
Marc or was it bill coming on to liz?
Embrace patina
