Author Topic: Ballards Plastic Renew  (Read 4125 times)
Offline Paul552
  • HEAVEN #552
« on: November 24, 2012, 07:15:46 pm »
I'm sure this been asked a million times but is the ballards plastic renew the best way to polish up a plastic tank.
Mines white and has gone quite yellow along where the pipe runs.
Will this take away the yellow or is there a better method?
Re: Ballards Plastic Renew
« Reply #1 on: November 24, 2012, 08:41:50 pm »
No.
plastic renew won't take the yellow out of your white tank, most of that is from the fuel/oil mix vapours leaching through the plastic over a number of years, the discolouring usually goes through the entire thickness of the plastic.
The final glossy layer of the renew is just a coating (similar to armour all, but a bit tougher) and washes off when it comes in contact with fuel.
It does a good job of the rest of the plastic on the bike though.....but's a lot of hard work. It's fairly expensive and is sometimes easier just to buy some new plastics if avaliable.
For the tank, easiest way to get it back white is a sticker kit.
What bike is it?
Offline Paul552
  • HEAVEN #552
« Reply #2 on: November 24, 2012, 08:48:06 pm »
No.
What bike is it?
It is a yz125d
I am waiting on plastics from Maxwell
I got a full sheet sticker from VMX unlimited (I got it next day unbelievable service) for the tank.
I was hoping to get it bit better but I will clean it and add the full sheet sticker
You have saved me killing myself trying anyway!!!
Thanks for the advise
Paul
« Reply #3 on: November 25, 2012, 12:44:46 pm »
Madness!
If you look at the VMX Unlimited website, you'll notice that they offer front and rear guards for YZ-D/E/Fs that are described as "exact reproductions".
They are SO much better than the DC Plastics ones - probably the best repro plastics available for any old bike.
VMX-U also sell new white tanks, if you're prepared to spend the money. I assume they're Clarke ones, which I believe are good but not perfect.
It's supposed to be possible to bleach old white tanks back to white.
« Last Edit: November 25, 2012, 12:46:37 pm by Nathan S »
« Reply #4 on: November 25, 2012, 01:08:38 pm »
I've got the Concorse plastics in stock, only a few sets left and that maybe the last you'll see of them as as I understand it, there tooling is worn and damaged and the cost to repair may negate the remanufacture of more guards.....as Nathan says, they are the best by a country mile. PM me if you want some....have yellow and white.
« Last Edit: November 25, 2012, 08:59:52 pm by Davey Crocket »
« Reply #5 on: November 25, 2012, 08:30:25 pm »
...or troll ebay 'til some NOS plastics come up.
I have never had any good DC stuff, and won't even buy it now. I would rather wait till some clean second hand stuff comes up on ebay.
Have you had a search done on Yamaha dead stock list for plastics?
Offline PCMAX
« Reply #6 on: November 25, 2012, 08:40:19 pm »
I've heard that soaking the white tanks in bleach for a couple of days (inside & out) will restore the white. Don't tnow of anyone who has tried this but perhaps someone here might be able to comment.
Offline PEZBerq
  • Brisbane
« Reply #7 on: November 25, 2012, 09:52:39 pm »
Extremely limited success with bleaching or hydrogen peroxide treaments of Acerbis white tanks on Husky's. By all means scrape with a blade to get the outer layers off and then sand and polish. Then fit a full cover perforated white decal and cut out for the colored decal or fit a full coverage kit from MXM or the like. Comes up a treat but is not OEM original of course.
Offline Paul552
  • HEAVEN #552
« Reply #8 on: November 26, 2012, 07:11:26 pm »
I ordered a full set from maxwell as vmx unlimited were out of stock on some parts.
I assume they are DC
Hope they look ok when they arrive
