Author Topic: CR500RE Gearbox  (Read 6136 times)
Offline E74
CR500RE Gearbox
« on: April 18, 2008, 03:17:03 pm »
Can anybody tell me where I might be able to get a new gear set for a 1984 CR500RE?
Re: CR500RE Gearbox
« Reply #1 on: April 18, 2008, 04:10:26 pm »
G'day E74,
US Ebay had some RE 500 G/box clusters a week or so ago listed.
Offline paul
Re: CR500RE Gearbox
« Reply #2 on: April 18, 2008, 04:31:23 pm »
i can get them made  gears, shafts what ever .ALL I NEED IS A SAMPLE  AND THEY CAN CUT NEW GEARS ETC BUT ITS NOT CHEAP   SO WORK OUT WHAT YOU NEED AND !!!!!!!!
« Last Edit: April 18, 2008, 04:37:23 pm by paul »
STW996
Re: CR500RE Gearbox
« Reply #3 on: April 18, 2008, 06:52:35 pm »
E74 Like Hoony said Ebay in the states is the go, just purchased a hole gearset and selectors for 185 AUS plus 44 AUS freight. One new gear alone would cost more than this to buy. Most just neet the dogs back cut and in most cases all is good to go. Most of the thrust washes and shims are the same as later model items and can still be purchased for Honda. The 84 box is pretty much stand alone (not sure of the 85 box) but the 86 box part numbers are not the same, so it will be an 84 box your after.
Shane
Re: CR500RE Gearbox
« Reply #4 on: April 18, 2008, 07:06:46 pm »
if you need to know if 84,85,86,87 parts are same/interchangable i can let you know as i have parts fiches and a parts book that covers these models.
Offline Swamper1
  • Swamper1...no helmet days-elsinore rider ;)
Re: CR500RE Gearbox
« Reply #5 on: October 14, 2014, 10:48:13 pm »
Hi,
i'm restoring a cr500 87 and may need to replace all the transmission gears....will 93 gears do the job? was looking on partzilla for parts and noticed the 93 gears were all the same teeth...i'm new to restoring..so any help would be great.
Re: CR500RE Gearbox
« Reply #6 on: October 15, 2014, 01:24:36 am »
The following page might help you.  I have a couple of dodgy gears in my 84 CR500, they are the same as 85 model (KA5 model code) but the later models are ML3 model code.
It appears from this chart that 88 thru 92 have a lower 4th & 5th to all the other models before & after those years.  But I dare say that they might interchange if you use the matching gear from both shafts?  All CR500's from 84 to 01 run the same shift-forks.
http://www.thumpertalk.com/topic/801181-1991-cr500r-stock-gearing/
« Last Edit: October 15, 2014, 01:29:43 am by John Orchard »
Offline Swamper1
Re: CR500RE Gearbox
« Reply #8 on: October 15, 2014, 11:32:47 am »
Thanks John. My biggest concern was that the last three digits are different on the part numbers of the 93 gears
on partzilla's page. eg 4th gear for 87 = 23461-ML3-000........4th gear for 93 = 23461-ML3-670.
Offline Swamper1
Re: CR500RE Gearbox
« Reply #9 on: October 15, 2014, 12:25:39 pm »
Maybe they need to update there site on some of the other gears, as this one ends in 000 on the 87 page, and 670 on the 93 page, and is compatible with the 87 on the 93 parts page  ::)
23491-ML3-670 GEAR (19T)
Description
Purchase this Honda 23491-ML3-670 GEAR (19T) --- GEAR, COUNTERSHAFT FIFTH (Honda Code 4118030), GEAR, COUNTERSHAFT FIFTH (Honda Motorcycle Code 4118030)
This Honda 23491-ML3-670 GEAR (19T) is used on these models and components:
1986 CR500R A TRANSMISSION
1987 CR500R A TRANSMISSION
1993 CR500R A TRANSMISSION
1994 CR500R A TRANSMISSION
Re: CR500RE Gearbox
« Reply #10 on: October 15, 2014, 09:33:05 pm »
I have a multi language( you can nut it out ;)) PDF (10.7mb) of the parts books for CR500 RE through to RK models. If any would like a copy send me a pm with an email address and I will see if it sends to you. cheers Tim754
