Author Topic: bellcrank/cushion lever bearings  (Read 1830 times)
Offline Ktm181
« on: November 24, 2012, 10:07:20 am »
Hello Suzuki family!
Need to pick your brains, i will be needing bearings for the bellcrank/cushion lever shortly, in particular the small spherical ones in the rear of the bellcrank that connect to the top of the "struts", Suzuki part number 09269-08001 (RM500D,RM465X & Z), do any of you know of a reliable source other than original Suzuki?????? If no can you recommend your favourite source either here or overseas?  As you have no doubt found they around the $140 mark in Aus and approx $65 in the U.S.
Thanks for your help,
Kt.
