Author Topic: Aligning engines  (Read 3163 times)
Offline Rosco86
  • Brisbane
Aligning engines
« on: April 18, 2008, 01:24:02 pm »
Just working on a new project that has had a different motor placed in it. Looking for ideas as to the bvest way to reposition an original type motor in it. All engine mounts have been removed from the front and it has an unusual rear mount using alloy plates slotted around the swingarm to suit another type motor.  Know about chain alignment but it also has a non standard rear wheel, but i can deal with that when it arises. More concerned  over height from frame and angle tilt on motor. Would be easier if it was a maico, bulty etc where there is ample examples, but I am having difficulty getting much info, pictures, knowledge around a 1972 KTM with the sachs 125 motor. Motor position is important as it uses an up- through the frame exhast pipe. Any thoughts gladly considered.
Rosco86
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: Aligning engines
« Reply #1 on: April 18, 2008, 01:35:26 pm »
i'm probably only stating the obviuos Rosco, but i'd bolt as much as possible together,motor,carby,airbox,exhaust,seat,tank {are there any exhaust mounting brackets you can use?},and chock it in place with whatever works, wooden wedges or temperary brackets. instead of putting bolts through the motor, i would try and use long lengths of round bar at first as the front sprocket is usually at 90 degrees to the engine bolts. you can square the motor up in the frame by measureing from the round bar {if that makes sense}. with another round bar through the swingarm pivot, it will aid in thos crucial measurements.
oh, and have a cold beer and some patience on hand.
"flat bickie"
Offline zorroz
« Reply #2 on: April 18, 2008, 05:01:32 pm »
You talking about the bike that was advertised here from Newy?
oz555ktm
« Reply #3 on: April 19, 2008, 11:19:44 pm »
G'Day Just like to help if I can .
Is this a red 1982 KTM 125 cc Roller that you got .I Very Goo Nick ?????
Was it for sale hear on the For Sale Part of Ozvmx .
Is this the Bike that ZorroZ was selling for a Mate
I do think that that bike was cut up to fit a Assap engine .
The bike was a goer but the guy who got this remove the engine as He is a Mad Assap colecter.
The Mods were done by a Guy Name Chris ##### from Melborne VIC
and was Very well done .
To refit a KTM engine back in may be Fun .
If this is ALL TRUE than Let me Know and could Be a Help to You
« Last Edit: April 19, 2008, 11:27:16 pm by oz555ktm »
« Reply #4 on: April 20, 2008, 09:10:51 am »
Swing arm pivot point to countershaft centre to centre distance is very important(closer the better) and that they are on the same height.Higher or lower will promote or reduce squat under power in the rear.Next is chain aliagnment, this must be straight.The rest isn't as important as these two things.
