Author Topic: IT/YZ 250D pre78 project  (Read 29452 times)
Offline Paul552
  • HEAVEN #552
Re: IT/YZ 250D pre78 project
« Reply #45 on: March 07, 2013, 07:44:19 pm »
Did you tig weld it? (the nice pipe)
I have seen a few done with oxy (fusion weld)
Offline head
« Reply #46 on: March 07, 2013, 09:47:19 pm »
Yes, that was my first pipe with the Tig, I have made some with the oxy in the past. If you get yourself a #6 tip the oxy works well. Tig worked well also. Was down to about 15 amps for most of it.
Cheers Neil
« Reply #47 on: March 08, 2013, 09:11:02 am »
It was 786mm
How hard are you going to rev it ? That TL will give peak power at around 13,000 rpm.
Offline head
« Reply #48 on: March 08, 2013, 10:10:27 am »
Only playing with you. 1020mm
« Reply #49 on: March 08, 2013, 12:09:06 pm »
That will still be a tad peaky 1150mm would be peak at 8500rpm
Offline head
« Reply #50 on: March 08, 2013, 12:13:58 pm »
I worked it out for 8000rpm peak power. The cylinder has fairly long duration on exhaust port.
Offline Paul552
  • HEAVEN #552
« Reply #51 on: March 08, 2013, 05:16:53 pm »
Did you also modify the ports?
Offline head
« Reply #52 on: March 08, 2013, 08:01:31 pm »
Yes the cylinder has been modified.
« Reply #53 on: March 08, 2013, 08:38:56 pm »
Port timing is irrelevant the pipe decides when peak power is.
Offline head
« Reply #54 on: March 08, 2013, 09:50:28 pm »
Yes I understand that, but don't you use exhaust timing to work out tuned length. If you do not now the exhaust duration how can you work out a length for pipe. What formula do you use Lozza?
Offline OverTheHill
« Reply #55 on: March 08, 2013, 10:51:26 pm »
bought an IT400 motor from a wreckers many moons ago & fitted into a DT250 monoshock frame to go vmx-ing, used a pipe that should have been ideal off something like a 400-465 it or yz but was terrible [all top end, dangerously high rpm for an old shitta]. Found someone had-had a good play & it had 192 degrees exhaust duration so in desperation i added 100mm to header pipe [took a guess as couldn't find my 'graham bell' book] & transformed it luckily. [pages all fell out of both my graham bell 2 stroke & 4 stroke books in the end].
Offline head
« Reply #56 on: March 09, 2013, 10:17:41 pm »
After a few initial dramas I finally got a decent ride on it today. Power seems good, with a good strong surge. May try and lighten the IT flywheel a little bit. But other than a bit of fiddling i think it is ready to race.
Offline Ted
« Reply #57 on: March 09, 2013, 10:57:55 pm »
It certainly looks ready. Fantastic job buddy. Now pull your finger out and do the 465 before them gears rust away.
81 YZ 465 H   77 RM 125 B
TM BILL
« Reply #58 on: March 19, 2013, 09:13:23 am »
That looks great  8) i envy talented people who can build a bike like that and even design and build their own chambers  :)
Offline oldyzman
  • 250 two stroke!
« Reply #59 on: December 04, 2015, 10:05:03 pm »
10 out of 10 for our effort on the pipe. Hope it works just like it looks.
