Author Topic: 43mm Yamaha forks.  (Read 3081 times)
43mm Yamaha forks.
« on: November 21, 2012, 02:42:52 pm »
I just got a bit lucky, scoring these IT490 forks for $19.99US. They've only got to be shipped from Bakersfield to Long Beach (Penrith-Sydney distance) which should be pretty cheap. They should owe me about $50 landed. Cool.  Has anyone got a set of triple clamps to suit? A TLS backing plate?
                                                      http://www.ebay.com/itm/350642408557?item=350642408557&viewitem=&sspagename=ADME:B:EOIBSA:AU:3160&vxp=mtr
« Last Edit: November 21, 2012, 03:05:28 pm by firko »
Offline curly001
Re: 43mm Yamaha forks.
« Reply #1 on: November 21, 2012, 09:13:30 pm »
Mark should have a backing plate will check and let you know. Curly
Offline bishboy
  • Toowoomba
« Reply #2 on: November 21, 2012, 09:49:08 pm »
Damn, I'll be needing a set of these soon.  I need to pay more attention to ebay  :(
Are you getting them shipped over in a container?
« Last Edit: November 21, 2012, 09:51:16 pm by bishboy »
« Reply #3 on: November 21, 2012, 10:37:35 pm »
Yep, that's correct. I'm getting them shipped with my new old Maico and a couple of pipes I've purchased by container.
« Reply #4 on: November 22, 2012, 09:53:25 pm »
Did you have any luck Curly?
Offline 09.0
« Reply #5 on: November 22, 2012, 10:17:39 pm »
What are you using them on Firko?
Are they as good as yz forks? I have a set of yz triples,43mm
« Reply #6 on: November 22, 2012, 10:23:18 pm »
They're replacing the 38mm forks on my IT250H Brad. I thought I'd trick the old girl up just a little to do a couple of vinduro's next year. I don't know what the difference is between the IT and YZ forks but I doubt it'd be much, I'm interested in finding out though.
How much do you want for your triple clamps Brad?
« Reply #7 on: November 24, 2012, 12:31:36 pm »
If Curly can't help then I should be able to next week, have a 490 brake plate coming that I only want the alloy arms off, will swap the steel arms off my 465 onto it & it's yours if needed
Offline 09.0
« Reply #8 on: November 24, 2012, 09:35:56 pm »
nothing,zero,nada. Pm me your address.
« Reply #9 on: November 24, 2012, 09:38:24 pm »
Thanks Brad. PM on the way.
Thanks to you too Tony ;D
