Author Topic: Yamaha DT100/125/175 rear wheel spacers  (Read 1661 times)
Offline Tex
« on: November 16, 2012, 09:26:05 pm »
Can someone help with width measurement of RHS rear wheel spacer of a twin shock small capacity DT? Mine's a '77 125, that came with random pieces of scrap metal inserted where the spacers should be. I've found replacements, but RHS one is clearly too wide. Even an approximate measurement would assist.
Re: Yamaha DT100/125/175 rear wheel spacers
« Reply #1 on: November 16, 2012, 09:45:00 pm »
i brought a complete rear wheel off the dump shop for $5 complete with axle/adjusters/backing plate and spacers so will measure tomorrow and report back or for a few dollars and post ill knock one up at tafe
« Reply #2 on: November 16, 2012, 10:43:09 pm »
24mm width  26mm OD   15mm ID and no fancy weight saveing machining like the yz spacers ;)
Offline Tex
« Reply #3 on: November 17, 2012, 07:10:41 pm »
Thanks TT5 Matt, that's great. I should be able to make one up out of the spacers I have, just needed some idea of the proper size.
