Author Topic: dt ignitions  (Read 6357 times)
Offline caps 999
dt ignitions
« on: August 13, 2007, 04:44:32 pm »
my dt 1 ignitions giving me hell does any one out there have a replacment or will any other ignitions wotk ie:dt250a dt2 dt3 ???
MUGEN power
Re: dt ignitions
« Reply #1 on: August 13, 2007, 05:00:18 pm »
YEs to all, but best you replace that 30 year old shitter with a new one that will work for another 30 years.  Lozza the korean import guru should be able to map you up a complete ignition system.  Set it and forget it ! other wise you end up chasing your tail as each section slowly falls over.  Problem with fitting one new bit can often overload the other old bit and the crumbling chain starts.............
Failing that your living with filing points in the mud for the rest of your life.
« Last Edit: August 13, 2007, 05:04:13 pm by Freakshow »
Offline caps 999
Re: dt ignitions
« Reply #2 on: August 13, 2007, 05:27:05 pm »
thats great other thing is does anyone have a dt1 wiring diagram
MUGEN power
Re: dt ignitions
« Reply #3 on: August 13, 2007, 08:23:54 pm »
i have a CycleServ manual for the DT1- E and DT1- mx same bike same book.  The DT 1 mx bit is at the back :O) interestingly it notes the differance between the GYT parts and the  standard parts : any way has the electrical diagram but looks lke most of the connections are for the road kit, but colours etc all clearly marked.   MAke me a god offer and pay the postage and its on the way !  actualy while i think of it ill post some other manuals in the sale forum if any you guys up for it  :D.
« Last Edit: August 13, 2007, 08:26:53 pm by Freakshow »
Re: dt ignitions
« Reply #4 on: August 14, 2007, 12:39:21 pm »
A god offer? Seems a bit steep for an old Yammie manual!?  ;D
Re: dt ignitions
« Reply #5 on: August 14, 2007, 04:17:38 pm »
yes not the hell offer
Offline caps 999
Re: dt ignitions
« Reply #6 on: August 27, 2007, 05:05:09 pm »
freaky do you still have one of those ignitions  give us a pm if you do
MUGEN power
Re: dt ignitions
« Reply #7 on: August 27, 2007, 08:06:00 pm »
i never said i had an ignition, i responded yes to the wiring diagram part of your post. lozza has the new ign sets ?
