Author Topic: Airshox bladders  (Read 3031 times)
Airshox bladders
« on: November 12, 2012, 07:26:22 pm »
I'm in the process of replacing a bladder due to a leak, which turned out to be a decent sized split (20mm) rather than the pinhole I thought it might be. The bladder was new when installed last year, and I was surprised today to see how stiff it was compared to new.
I'm wondering whether the Castrol fork oil I'm using has some additive that has caused a problem, or whether the rubber compound was defective?
Has anyone else had issues with repro airshox bladders?
Offline crs-and-rms
  • heaven 23
Re: Airshox bladders
« Reply #1 on: November 12, 2012, 07:36:17 pm »
fork oil can not handle the heat that shocks generate the viscosity index is to low id be using  shock oil with the highest viscosity you can find
Offline motomaniac
« Reply #2 on: November 12, 2012, 08:22:17 pm »
there was a batch of dodgy bladders coming from the US a few years ago that didnt last long .Maybe you ended up with a pair.
« Reply #3 on: November 12, 2012, 09:06:38 pm »
Interesting about the dodgy batch? I'll see how the other shock holds up.
Is there a difference between shock and fork oil? Thor's site mention's both as suitable.
« Reply #4 on: November 12, 2012, 09:44:01 pm »
Fork oil isn't good enough, I tried it in a modern shock when i ran out of shock oil, a couple of rides later i pulled the shock apart and the oil was black, burnt and it stunk.
« Reply #5 on: November 12, 2012, 09:53:48 pm »
Any brand/type to look for?
Offline motomaniac
« Reply #6 on: November 12, 2012, 09:55:25 pm »
Agreed , its amazing how many times I had a someone tell me in a shop , when they had no shock oil to sell me , that its the same stuff ."Mate we use it in shocks for guys who do the Aussie SX series" yer right!
It shouldn't  wreck fox bladders though.
Offline motomaniac
« Reply #7 on: November 12, 2012, 09:59:04 pm »
I use Racetech because I can buy it by the drum , its cheaper that way, and because the distributor is local to me , although I order it through a shop its makes it quicker.
« Reply #8 on: November 12, 2012, 10:06:52 pm »
I use Motorex shock oil in a 5 litre container. If you can find a shop that sells Showa or Honda Shock oil it's also very good and is available in a 1L tin. I was using Motul but had a couple of bad bottles that went lumpy when the shock got hot.
« Reply #9 on: November 12, 2012, 10:37:15 pm »
Cool, thanks guys
