Clubroom
Tech Talk
rm250b coil
Topic: rm250b coil (Read 2062 times)
hagon_84
B-Grade
rm250b coil
November 03, 2012, 07:39:52 pm »
just wondering if anyone had any info they could share on a rm250b coil it seems to be a sealed unit not being able to change the coil lead to the plug i am pretty sure i got a break in it as seems reasonably stiff with a soft spot in it and depending on the way u hold it there is a faint spark comin from must be as it makes contact inside the rubber coating. I have a coil off a 93 model kwaka kx 80 i was goin to use it to see if thats where the problem lies but before i do i want to make sure its safe to test with and does anyone no where i can get a new coil for the bike or do they still make them any info would be great
1977 Hagon rm250b, 1977 yz400d, 1972 gauzonni rm125, 1969 greeves griffon 250, 1973 greeves griffon qub 380, hagon eso 500.
Re: rm250b coil
November 03, 2012, 08:39:33 pm »
Cut the wire off at coil housing... now find a screw about 30mm long ( neddle point buggle head ) screw it in about 10mm to 12mm - now cut the head off and put a point on the exposed end .... screw on a new lead putiing a dob of silicon at the join.
Job done
Last Edit: November 03, 2012, 08:50:26 pm by oldfart
hagon_84
B-Grade
Re: rm250b coil
November 03, 2012, 09:01:00 pm »
thanks for the tip i almost feel like goin out and trying it now but the neighbors probably tell me to get f@#ked if i start the ol girl up tonight
matcho mick
Re: rm250b coil
November 04, 2012, 01:10:39 pm »
no no no!,
file the top of the coil down following the h/t lead remains,(expose the top of the lead where it lays in),it's just pushed into a spike,renew lead,shove it into the spike,& epoxy over it,(araldite??),bingo,your'e good to go!
hagon_84
B-Grade
Re: rm250b coil
Reply #4 on:
November 05, 2012, 08:27:40 pm »
i cut the glue away from the end of the coil and managed to break it free so i was able to put a new lead into it correctly works perfect
Clubroom
Tech Talk
rm250b coil
