Author Topic: rt 360 exhaust port opening angle atdc  (Read 2185 times)
Offline Andrew L
« on: October 31, 2012, 09:23:14 am »
Has anyone measured the exhaust port opening angle atdc on an rt3 360 with stock porting any help would be great.cheers mav
Offline facthunt
Re: rt 360 exhaust port opening angle atdc
« Reply #1 on: October 31, 2012, 11:57:20 pm »
Old notes say 92atdc for DT360A. RT2/3 should be close.
Offline Andrew L
« Reply #2 on: November 01, 2012, 12:07:04 am »
Thanks for that facthunt im making a new expansion chamber and the program I am using for part of the design requires that info, you,ve saved me a few hours of rootin around with a degree wheel, I used the figure 95atdc in my calculations so not far off. cheers Mav
