Author Topic: Shock re mount  (Read 3016 times)
Offline jimson
  • Sanctuary point N.S.W
Shock re mount
« on: April 15, 2008, 10:08:17 pm »
I have a brand new pair of shocks for my DT1 but the chain is in the way would it be possible to mount the shocks on the outside of the bracket instead of inside if I beaf up the mounts.I want this bike for CD5 so I have to get my act together.  :o jimson
Re: Shock re mount
« Reply #1 on: April 15, 2008, 10:20:24 pm »
will the top hit the pipe if you space it out ?
I spaced a pair of Mulhollands with a huge set of finning  out  on a TS once  but then Suzy's have posts not brackets.
If they are still verticle and you can support the mounts I cant see why not But it aint going to look all that flash.
Offline jimson
Re: Shock re mount
« Reply #2 on: April 15, 2008, 10:25:12 pm »
Pokey look flash your joking mate I look like a hat full of assholes so what chance has my bike got when I'm on it.  ;D as long as it works mate.jimson
Re: Shock re mount
« Reply #3 on: April 15, 2008, 10:33:25 pm »
The standard Yamaha set-up where the bolt is in double shear is definitely better, but plenty of things have shock bolts in single shear without drama.
If you were to do the long bolt in single shear thing, get a new high-tensile bolt and run it through both parts of the existing mount as well as the shock (in other words, don't try to mount it off just the outer part of the existing mount, because you WILL bend the mount and/or the bolt).
