Marque Remarks
Suzuki
oil lines needed
Topic: oil lines needed (Read 2955 times)
cocksprocket
oil lines needed
October 27, 2012, 04:30:42 pm »
hey guys, anyone out there have a set of the oil pump lines for a 1975 tm250 they are willing to part with?? also where is the best place to get a wiesco piston kit for the above bike?? cheers
lukeb1961
PE175N, RM80B, JR50C
Re: oil lines needed
October 28, 2012, 07:31:17 am »
eBay. try searching for "TM250 wiseco" or "380M07000" readily available circa $101.00
Alpha-Sports lists the lines as still available.
http://www.alpha-sports.com/suzuki_parts.htm
Try calling
Ray at Suziparts in South Australia,
http://www.suziparts.com.au/
or Kessners -
http://kessnersuzuki.com.au/
or Steve at Mick Hone Suzuki in Victoria
http://www.mickhone.com.au
or Tony at
http://vintage-suzuki.com/en/
Luke
http://members.optusnet.com.au/pe175n
October 28, 2012, 07:55:41 am »
Yep ....I have 1 sets plus pump
I have done the LHS mod. flick us an email
cocksprocket
October 28, 2012, 10:32:19 pm »
pm sent old fart!!, thanks lukeb for the info
used to work at Kessners a long time ago and remember ray coming on his old sidecar to pick up parts!!
cheers for the help
Gerard De Ruyter (Twistandshout)
A-Grade
Reply #4 on:
November 07, 2012, 01:27:43 pm »
Oldfart, what's the 'LHS mod'?
Reply #5 on:
November 07, 2012, 03:47:34 pm »
You need to split the cases and remove the crank to do this ....
Basicly removing the oil pump- line's - oil tank & slinger plate, drilling a hole on LHS so the 2 stroke pre-mix feeds the bearing.
Marque Remarks
Suzuki
oil lines needed
