Author Topic: how do you remove anodise  (Read 2262 times)
Offline paul
« on: October 18, 2012, 05:51:31 pm »
got a gold alloy rear sprocket and i want to remove the gold anodise ,how do you do it ?
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: how do you remove anodise
« Reply #1 on: October 18, 2012, 06:00:21 pm »
I've heard oven cleaner does the trick.
Ban BLACK rims NOW
Offline YZ250H
  • Back in QLD Baby !
« Reply #2 on: October 18, 2012, 06:03:17 pm »
Alibrite from Supercheap, but don't get it on yourself and wear safety glasses.
Offline flower pot racing
« Reply #3 on: October 18, 2012, 06:19:44 pm »
take it to an anodisers and get them to reverse it.
Lot of effort for a sprocket.
Surely buy a new one.......?
« Reply #4 on: October 18, 2012, 06:51:01 pm »
I use this method ....use a phosphoric acid bath at about 20 precent phosphoric acid to 80 precent water (1 gal. of acid to 4 gal. of water ratio) heat liquid to 190 degrees. then submerge part depending on size for 1 to 3 minutes.
I'm a anodizing line operator
Justin Ridenbaugh
- Newark, Ohio
I also use citric acid to clean rims
Oven cleaner is Caustic based ....
Offline Noel
« Reply #5 on: October 18, 2012, 08:32:43 pm »
Caustic soda, (read Draino )
will remove anodising, your call !!!!.
Noel
« Reply #6 on: October 18, 2012, 09:46:46 pm »
Caustic soda, (read Draino ) will remove anodising, your call !!!!.
I learned that one the hard way when I mistakenly (don't ask ) used garage floor cleaner (caustic) to remove some rock hard mud'n'stuff from my wheels. The result wasn't pretty.
