Author Topic: Are Yamaha twin leading shoe front brakes Pre78 eligible?  (Read 9164 times)
Offline mboddy
  • Canberra
« on: April 15, 2008, 07:15:11 am »
I had a great day at Heaven Round 2 in Canberra on the weekend.
My first MX meeting in 30 years!
It showed up a few things that I need to sort out with the bike.
The front brake was really bad.
I noticed the YZ250C was using a Yamaha twin leading shoe front brake.
I haven't been able to find any evidence that this was available pre 1978.
Vinduro Penrite Team
Re: Are Yamaha twin leading shoe front brakes Pre78 eligible?
« Reply #1 on: April 15, 2008, 08:02:56 am »
I wasn't aware they were Pre 80 legal.
« Reply #2 on: April 15, 2008, 09:05:07 am »
The Yammy brake was renowned as the best of the period so if you were noticeably down on brakes either
1/ you're forgotten how to brake in the dirt   ::),
2/ your brake wasn't set up correctly in some regard  ;), or
3/ you're just riding too fast  ;D.
I'm no expert but I don't think t.l.s. brakes appeared on production mx'ers until about '82.
« Reply #3 on: April 15, 2008, 09:38:38 am »
In a word...No.  I agree with Graeme that the Yamaha brake is the best in the business. I'd be checking my cable to test if it's stretching , and looking for soft compound modern brake shoes. Are your shoes the originals? Are you used to riding a disc braked modern bike and are expecting similar stopping power from your old YZ?
Offline mboddy
  • Canberra
« Reply #4 on: April 15, 2008, 06:30:06 pm »
The cable is stuffed. The hub is oversize.
I have a new cable coming as well as a very good hub.
I just wanted to make sure that when I have finished I had the best front brake that was eligible.
Thanks, Mark.
« Reply #5 on: April 15, 2008, 06:49:06 pm »
Since the question was asked, when was the first t.l.s. MX brake released on a production bike? And what make model?
Offline YZ250H
  • Back in QLD Baby !
« Reply #6 on: April 15, 2008, 07:08:49 pm »
Pretty sure the first Yamaha was YZ465H (81), but I could be wrong.  I think they went on the 250's as well in 82.
« Reply #7 on: April 15, 2008, 07:20:57 pm »
If you do all of the tricks to the IT hub, and are still unhappy, then there's also the XT500/DT400 front hub/brake to use.
Same style of conical hub, but significantly larger in diameter (sorry, can't remember the measurement).
Rosco400
« Reply #8 on: April 15, 2008, 07:22:11 pm »
Honda released the 1975 SL175 street scrambler with TLS, mx no but they could have been adapted back then although dont know if was ever done ::)
« Reply #9 on: April 15, 2008, 07:25:51 pm »
Montesas had them in the mid 60s. Check out the La Cross in my piece in the current VMX.
Offline suzuki27
« Reply #10 on: April 15, 2008, 07:52:17 pm »
The tls first appeared in the 1920s-designed by an aviation engineer and very soon after found there way onto road bikes.I have a picture of a 4 leading shoe(Full width hub) on the front of the Factory 350 Benelli in a 1939 GP. Heat was a problem and venting was essential to delay fade.
« Reply #11 on: April 15, 2008, 11:03:16 pm »
For a little while I ran a Suzuki GT750 4 leading shoe on the outfit, way too heavy and F***all braking when dry, heaps less when wet, replaced it with an SL350 Twin leader .. Much lighter and same braking performance.... So if you rocked up with a steel rim 19 inch SL350 up front there is your legal twin leader......  :D Check out your Yammies brake it should be very nice!
« Last Edit: April 16, 2008, 05:29:59 pm by Tim754 »
Doc
« Reply #12 on: April 16, 2008, 04:10:39 am »
the '69/'70 TS250 Suzuki was the first from the jap manufacturer to run twin leaders on production dirt bikes  ;)
« Reply #13 on: April 16, 2008, 08:04:03 am »
At the 2nd (and last?) Castrol 6 hour at Nepean I run a yds5 hub, t.l.s. brake, hooked up to a 19in rim. We did it primarily because the small brake faded to zero brakes at the 90 degree left after about an hour.
When was the 2nd Castrol 6 hour at Nepean ? '76/'77? Would this arrangement be pre '78 legal?
Mind you, Bobby Mayes of Willoughby club was running a CB750 disc on his Maico in about '74.
211kawasaki
« Reply #14 on: April 16, 2008, 11:55:55 am »
if the disk was available pre78 its OK as is a TLS drum, where you come unstuck is when you use a later item and try and get it passed. None of its a problem when you consider the period and work within it.
211
