Author Topic: RL250 clutch  (Read 3800 times)
Offline Nobby25
  • Could possibly fit other models?
RL250 clutch
« on: October 11, 2012, 01:58:17 pm »
I am currently restoring a 75 RL250 and about to start on the engine. I've never ridden one and I have read that the heavy clutch pull is an issue and that removing some of the springs helps, Is this the "hot setup"  :) ? or are there other springs you can use to lighten it up? I know a one peice push rod can help too.
Thanks Nob
TM125L RM250N TC125L RL250M PE175T RM80C RMX250T ATC70 YZ80B?
Offline David Lahey
Re: RL250 clutch
« Reply #1 on: October 11, 2012, 10:11:44 pm »
I would try it with everything working well, especially the cable, before taking springs out. You may be surprised at how good it is completely standard.
previous pseudonym feetupfun
