Author Topic: XR80 Big Bore Options?  (Read 17612 times)
Simo63
« on: October 11, 2012, 08:45:59 am »
This question is for the XR75/80 fanatics  :)
I'm rebuilding an XR80 for my young fella and wanted to rebore it so figured a big bore would be the go.
Not interested in going 120cc as it will still have standard carb, ports and pipe, just wanted a bit more grunt.
What are the options?
Offline Hardex
Re: XR80 Big Bore Options?
« Reply #1 on: October 11, 2012, 09:53:10 am »
leave it stock or buy a 125.Its that simple.
Simo63
« Reply #2 on: October 11, 2012, 11:08:24 am »
Thanks but not what I was after.
Anyone got any helpful ideas/hints/tips?
Offline smed
« Reply #3 on: October 11, 2012, 03:41:03 pm »
Wiseco & probably some others do a 2mm oversize piston that gives 83cc,I think thats as big as you can go with stock sleeve :)
Offline BETRIC
« Reply #4 on: October 12, 2012, 06:31:47 am »
 Simo you can use a CB400F piston in an XR80, it will take it out to around 98cc, you should be able to use the std carb as a TL125 uses the same size carb, I have a CB400F piston for my 78 XR75, it only works in the 5 speed XR75 if you use an XR80 crank and barrel, (you can't use a 5 sp XR75 crank and barrel as the crank stroke and barrel are to short) the CB400F piston is just over 50mm dia and has a 13mm piston pin, (does not work in a 4 speed XR75 motor) ;)
« Last Edit: October 12, 2012, 06:36:47 am by BETRIC »
DELTEK, 72 MINI TRAIL, 73/4 XR75, 77/78 XR75, DG MONOSHOCK FRAME XR75, REDLINE FRAME XR75, PK RACING MONOSHOCK FRAME XR75, JWRP XR FRAME, SL70K1, 81 CR80RB, TY80A/B, YZ80A/B/D, GT50/80A, GTMX80A, 73 GTMX, GT1, COOPER MX, COOPER ENDURO,MX360A,MX250B,YZ125X MX100, 72 XL250, TC100,TL125, TY250C,IT250J
Offline Hardex
« Reply #5 on: October 12, 2012, 07:49:24 am »
Offline ozyditcher
  • saddleback park made me leve Oz
« Reply #6 on: October 24, 2012, 03:55:06 pm »
http://www.socalxrs.com/   http://www.powroll.com/  http://www.webcamshafts.com/  I have built a lot of very fast xr75 80 100 . Do not port the head , the ports are two big for the stock motor.  A good reverse cone pipe, XR200 carb. web cam,  XR50 ignition,
Offline Dono113
« Reply #7 on: October 30, 2012, 02:38:32 pm »
Simo wouldnt have aspare head mate, just picked up project and it needs a head as the two I have has flogged out cam journals ???
1983 CR125R
2003 CRF450R
CB750K1
2005 YZ85
1969 TS 250
Offline 35elsinore
« Reply #8 on: October 30, 2012, 08:43:24 pm »
ozyditcher, I have a 77 xr75 [5 speed] bike laying around and a xr100 engine. Is there a good combo there I can mix to make a little rocket.
Cheers Troy
Offline smed
« Reply #9 on: October 30, 2012, 09:13:05 pm »
The 100 donk will bolt straight into the 75 chassis ;)
Offline ozyditcher
« Reply #10 on: November 05, 2012, 08:34:50 am »
Cheers Troy
The xr 100 will bolt in the xr75. Put a 120cc kit in it  and good reverse cone pipe on it this is a good cheep mod 10 hp. cam carb 12hp $$ . 130cc 14hp$$$,  148cc 18hp$$$$$$$$$.
Offline 35elsinore
« Reply #11 on: November 07, 2012, 06:30:02 pm »
Just purchased a bbr 120cc kit with cam [$289 incl freight], what carb would be best. Might leave the 77 xr75 alone and convert the flogged out xr100 frame into twin shock and steel tanker. The ideas are flowing now for a fun bike to flog around with the kids.
PS. would the standard ignition be OK.
Cheers Troy
Offline ozyditcher
« Reply #12 on: November 08, 2012, 12:31:21 pm »
Cheers Troy
                        honda XR 200
Offline 35elsinore
« Reply #13 on: November 08, 2012, 07:00:36 pm »
Thanks for your help, much appreciated.
Offline Tony.Brown
« Reply #14 on: February 09, 2015, 01:47:57 pm »
BETRIC can you tell me which head gasket is used with the CB400F piston? Is it XR100? Or is there a different gasket made for the increased bore size?
Tony.
