Author Topic: TM 250 oversize piston.  (Read 2727 times)
Offline Rider
« on: October 10, 2012, 11:37:47 pm »
My TM 250 barrel is out to 2mm oversize but needs a rebore. Has anyone found a piston that is compatable. I have used the largest size (72mm) that Wiseco supply.  Regards Terry.
Offline KTMaico
  • "Love or Lust it's always a Maico"
    • Maico Lovers & Fans
Re: TM 250 oversize piston.
« Reply #1 on: October 11, 2012, 12:13:16 pm »
I have found out that Wossner has a piston that will fit, but the skirt length must be reduced by a couple of mm's. The guys at Serco should know this and they have a technical note on what needs to be done. You can phone and check with Serco Wooloongabba Brisbane. I hope this helps.
Kevin
1981 Maico 490 (Special Build)
1979 Husqvarna CR250
1975 Suzuki RH250
1975 Suzuki RM125 S
1959 Mk1 Jaguar 3.4 4 speed manual with O/Drive
« Reply #2 on: October 11, 2012, 12:27:03 pm »
fit a new sleeve.  your over the 5%
Offline Rider
« Reply #3 on: October 11, 2012, 08:34:24 pm »
Thanks Kevin I will check out Serco.  Regards Terry
