Author Topic: DT/MX 360 and SC500 right hand crank seals  (Read 2950 times)
« on: October 06, 2012, 03:02:05 pm »
Hi gents , So all the NOS ones have gone has anyone found a source as Ive come up empty . A manufacturer has quoted me a more you order the less you pay deal . Anyone interested ? Iain
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: DT/MX 360 and SC500 right hand crank seals
« Reply #1 on: October 06, 2012, 07:23:42 pm »
I just rolled on down to my local yammie guru for some  DT250A seals...
Which are the same i believe as MX/SC/250/360/500blah/blah...
Over the counter, easy but exlensive...
"flat bickie"
« Reply #2 on: October 06, 2012, 09:22:38 pm »
Vandy I thought that the 360 and 500 had a one off seal due to the ballancer so differant  from the 250 ?
just checked the parts book 250 = 93103-40058 (sw -40-62-10 ) 360/500 =93103-38086 (sw-38-62-10)
« Last Edit: October 06, 2012, 09:47:36 pm by iainyz »
« Reply #3 on: October 06, 2012, 09:46:51 pm »
Ok found the differance its the primary drive gear on the mx 360 #363-16111-00  on the 500 and DTa 360. 363-16111-01 SC and DTa 445-16111-00  . problem solved as Im going to remove the ballancer to fit 5 speed mx gears also fit the mx 360 primary drive gear . Iain
hardhaacker
« Reply #5 on: October 10, 2012, 08:31:54 pm »
Hi guys I found this seal from suzuki part # 09289-38006 fits the right side crank on the 74 mx and :D dt 360.
I put the seal on my dt360 I race and have no problems, the seal looks exactly the same but in the suzuki maroon colour and it is a little bit narrower than the yamaha one.
But it sits on a new part of the crank which can only be a good thing.
Hope this helps you out baz. :D
« Reply #6 on: October 10, 2012, 08:47:18 pm »
suzuki GT 550
