Author Topic: RM125A jetting specs  (Read 12255 times)
« on: April 14, 2008, 04:47:26 pm »
Hello all,
Can anyone tell me the jetting specs for 1976 RM125A? Standard engine.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: RM125A jetting specs
« Reply #1 on: April 14, 2008, 05:18:52 pm »
On the stock 32mm Mikuni
Pilot jet = #30
Needle jet = R-0 (R-3 is the go though)
Needle = 60P5-3
Main jet #250-260 (factory options range from #210-#310)
Ban BLACK rims NOW
« Reply #2 on: April 14, 2008, 05:26:54 pm »
Cheers, That will be our starting point.
Thanks,
Offline Graeme M
  • Administrator
  • Canberra, Australia
« Reply #3 on: April 14, 2008, 07:26:09 pm »
I haven't the specs to hand, but I don't think it'd be a 60P5 needle - I'm guessing 6DP5.
*Edit: I went off for a search to see if this is correct, and in the process found this very useful page. Scroll about halfway down, plenty of tech bulletins for RM series from 75-77 or so. Includes the change from R-0 to R-3 for the RM125A.
http://www.ozebook.com/compendium/techbuls/index.htm
« Last Edit: April 14, 2008, 07:41:10 pm by Graeme M »
rm1976
« Reply #4 on: April 20, 2008, 11:31:55 pm »
trying to jet my 125s bogs badly down low pilot 20 main 180 needle top clip plug looks grey white any ideas
« Reply #5 on: April 21, 2008, 02:42:29 am »
VERY LEAN up the jetting on all stages,check float level,check for manifold air leaks
TT5 Matt
rm1976
« Reply #6 on: April 21, 2008, 08:52:42 pm »
great idea mat ...the thing is bike has new case seals,float levals checked, manifold is good and if you try to go richer anywhere its un rideable?       half to full throttle is great its just down low it wont pull
any ideas ????
« Reply #7 on: April 21, 2008, 10:52:09 pm »
Learn how to read a plug, check ignition and what heat range is the plug?
rm1976
« Reply #8 on: April 22, 2008, 11:27:00 pm »
ignition seems to be working good plug is b9es and is grey/white after a hi speed run ?
Maico31
« Reply #9 on: April 22, 2008, 11:32:37 pm »
20 pilot is too small.. try a 30 or 35.
« Reply #10 on: April 23, 2008, 12:02:36 am »
Check the CDI.  got a spare you can swap in for a test.  I smell zoki black box
« Reply #11 on: April 23, 2008, 06:58:06 am »
What check ignition means is to put a timing light on it and see if the timing mark correspond with the manual settings, not taking it out of the head and kicking it and watching the sparks!Your way to lean on the main should be around the 280 main jet.DO a plug chop when it's bogging and read the plug.
rm1976
« Reply #12 on: April 29, 2008, 11:04:12 pm »
hey guys thanks verry much for the input i think we are almost there, I went for a ride today and the bottom end is a lot better in fact verry good specs are mainjet 170 pilot 27.5 needle 3rd clip mixture screw2.25 turns.plug B8es grey in colour..............
its still a little doey down low but hey its a 125, and flat out in top gear it seams to hit a bit of a wall like it hits the rev limiter, maybe i am reving it too hard and expecting too much
« Reply #13 on: April 30, 2008, 02:31:23 am »
still too lean,plug should be tan colour    start rich and go down better than holed or siezed piston because of excess heat caused by leaness not to mention lack of power and flat spots,go play some more with the jetting
TT5 Matt
rm1976
« Reply #14 on: May 01, 2008, 11:18:55 pm »
18o main makes it run like a pig  i will try different pilot jet(thanks mr hattrick)
