Author Topic: alloy rim  (Read 1852 times)
Offline slider84
alloy rim
« on: April 13, 2008, 02:38:04 pm »
i am in need of an alloy rim 36 hole 18 inch  2.15 or 2.5 wide . dont care what it is off , must be straight, if you lay the rim down in front off you with the tube valve in front off you < close to you> the first spoke hole to the right must point to the ground.
thanks slider
