Author Topic: Bearing removal  (Read 4296 times)
Offline CRTAD313
Bearing removal
« on: September 26, 2012, 06:39:20 pm »
I'm replacing a set of steering head bearings this weekend and was told the easy way to remove the bottom one is run a bead of weld round the cone with an arc welder.
Question is will a mig welder work  and any other tips?
Re: Bearing removal
« Reply #1 on: September 26, 2012, 06:50:10 pm »
Should work, normally only need to do a couple of small beads. As the weld cools it causes the steel to contract & quite often the race will fall out under it's own weight
Re: Bearing removal
« Reply #2 on: September 26, 2012, 07:12:26 pm »
Mig/stick/tig even OXY will work
Offline frostype400
Re: Bearing removal
« Reply #3 on: September 26, 2012, 07:15:40 pm »
I am doing this too at the moment what is the best way to get the new bearing back on?
1971 tm400 and PE's
Re: Bearing removal
« Reply #4 on: September 26, 2012, 07:21:55 pm »
Having been to bearing school (Truely)
I use a large bit of key steel Normal 20x20 and about Penis length 200mm in my case  ;D
A good 1kg ball hammer.
Place it in the freezer over night will not hurt.
Ok a bit extra if you have trouble getting it in stright at the start. Steel shop/  buy two bits 50x25 flat bar 150mm long and 1 bit 1/2 inch threaded rod with 4 nuts and a few washers. drill two 5/8 holes in both bits, cut threaded rod to correct size place on the head stem bearing on the F/B and slowly tighten the nuts it should go easy if it dosent your alignment is wrong. Clear as mud  ;)
You can also use your steering stem with just the outer shell on the bottom if are very carefull
« Last Edit: September 26, 2012, 07:35:10 pm by Slakewell »
Re: Bearing removal
« Reply #5 on: September 26, 2012, 07:44:24 pm »
Getting the cone out of the frame is the easy bit, I just feed a long handled flat screwdriver down through the steering and give it a tap with a hammer, always just drop out. The hard bit is getting the bearing off the bottom of the steering stem.
Offline dt tas
Re: Bearing removal
« Reply #6 on: September 26, 2012, 08:52:00 pm »
When i put the new cone in i get the old one and run it around on the bench grinder to make it a tade smaller then use that on top of the new one that way it is the right size .Now have a small collection of cones so mostly have the right size .Also use a solid screw driver to punch them out .cheers george
Offline topari
Re: Bearing removal
« Reply #7 on: September 26, 2012, 10:23:23 pm »
My special tool. Welded to the bearing race and then bang. Works everytime.
topari
1979 IT400F, 1984 kdx200
Offline Frank M
Re: Bearing removal
« Reply #8 on: September 26, 2012, 10:32:36 pm »
for easy removal next time, grind two small oposite grooves in the bearing shoulder in the frame, befor you install the outer bearing ring.
So you can punch out the bearing from the upper side with a long small driver etc.
Offline CRTAD313
Re: Bearing removal
« Reply #9 on: September 27, 2012, 06:40:52 pm »
ok thanks
