Author Topic: should this be repaired  (Read 2293 times)
Offline paul
« on: September 17, 2012, 11:40:12 am »
Offline paul
Re: should this be repaired
« Reply #1 on: September 17, 2012, 11:40:50 am »
« Reply #2 on: September 17, 2012, 11:52:31 am »
Most definitely no repair needed there.
Just clean up the edges of the wound from burrs etc that could otherwise dislodge. I would put a small chanfer on the edges, to make sure the shift cam slides without incident.
Looks like the result of a cluster blow-up Paul :o
« Last Edit: September 17, 2012, 12:01:45 pm by MICK-DE »
Offline paul
« Reply #3 on: September 17, 2012, 11:59:38 am »
thanks mick  ;)
« Reply #4 on: September 17, 2012, 01:45:24 pm »
then again if your ever going to do it nows the time while its apart.
$20 weld and clean up now and you can forget for another 40 years.
