Author Topic: cr250 84 fork oil  (Read 3719 times)
Offline frostype400
cr250 84 fork oil
« on: September 15, 2012, 12:18:15 pm »
How much fork oil do 84 cr250 forks need?
 I thought they were xr600 forks but they are obviously cr because the top clamp has the bolts coming through from the back and the wheel is silver so I am assuming it is 84 from that.
It was on one of my pe400's it is going back on I changed the seals and put in new fork oil but to xr600 specs so I probably may have to much in there will be good to have a pe400 that can stop well. :)
1971 tm400 and PE's
Simo63
Re: cr250 84 fork oil
« Reply #1 on: September 15, 2012, 05:43:49 pm »
If I recall correctly 130mm from the top.
« Reply #2 on: September 15, 2012, 06:42:35 pm »
I run 10w 120mm from the top. You can run a bigger air gap if you like a softer fork.
Offline frostype400
« Reply #3 on: September 16, 2012, 08:51:53 pm »
Thanks I have to much in them but they aren't on the bike yet I will drain it set it to 120-130mm thanks. :)
1971 tm400 and PE's
Offline mustanggrahame
« Reply #4 on: September 16, 2012, 09:03:50 pm »
Hey Frosty, once you get your PE to stop well, how are you going to get it to go well, handle well or look nice?  ;D ;D Just kidding it was good to see you on a bike today.
Cheers, Grahame
Offline frostype400
« Reply #5 on: September 16, 2012, 09:36:18 pm »
It will do everything well but if it breaks I can ride the xr again.
Yeah it was good to get to a vinduro again even if I wasnt on one of my 400's.
1971 tm400 and PE's
