Author Topic: Pulser-Less CDI Units - How do they work?  (Read 10283 times)
Offline Andrew L
Re: Pulser-Less CDI Units - How do they work?
« Reply #15 on: October 05, 2012, 10:49:40 pm »
Have you had time to fit the unit and give it a run yet. Have collected a nos source coil, new cdi compatible spark coil just need the box now. cheers Andrew
« Last Edit: October 06, 2012, 07:56:54 am by mavman4200p »
IT400C
« Reply #16 on: October 08, 2012, 09:54:28 am »
Hi Andrew,
Unfortunately, been kept on the hop by work lately and haven't had a chance to fit it up..  Been dying to try it too!!
I'll post as soon as I do!
« Reply #17 on: October 08, 2012, 12:19:29 pm »
I'm presuming that this CDI unit will work with the DT400 ignition on one of my RT1's but I wonder if it'd work with the internal rotor MX250 ignition? Am I correct in thinking that the Rex pulserless unit replaces the standard Yamaha CDI box or does it run in conjunction with it? I'm waiting to see what IT400C thinks of it and if it's as good as the website says it'll be, I'm in for one ;).
« Last Edit: October 08, 2012, 12:23:16 pm by firko »
Offline Andrew L
« Reply #18 on: October 08, 2012, 01:50:43 pm »
It replaces the original CDI unit. When I emailed Marcus from rex's he said I would have to fit the cdi source coil  from a later bike not the points one as the points one put out to much power which would blow the box up and he recomended changing the spark coil to a cdi type one as well as he hadnt tried a points coil out yet, didnt ask about the mx250 type you could email him he was very helpful.
Offline Andrew L
« Reply #19 on: October 18, 2012, 09:21:28 pm »
Your moving on from just teasing us to human torture now. :-\ ;D
IT400C
« Reply #20 on: October 19, 2012, 06:15:45 pm »
Damn......  My Master Plan has been discovered....    ::) ::)
haha - been very busy with work, and just haven't had the inclination to make the time to do it while the bike's been working...  (I used the ignition off another bike prior to the Murphy's Creek Vinduro)...
 ;D
Offline Andrew L
« Reply #21 on: October 19, 2012, 11:31:27 pm »
My right leg aches with anticipation evey time you reply. Take your time for a proper evaluation I'll wait as the season is nearly over for vic vmx around here except for a practice day. cheers Andrew
« Reply #22 on: October 20, 2012, 12:03:44 am »
I can be bribbed into making the slack-arse finish it!!! ;)
« Reply #23 on: November 03, 2012, 05:08:48 pm »
It 400 the torture is starting to hurt .  :D any news for us . Iain
« Reply #24 on: November 03, 2012, 05:59:42 pm »
He's farked Iain.....enduro riders....what more can I say.
IT400C
« Reply #25 on: November 05, 2012, 09:08:24 pm »
Hey, if it ain't broke....    ;D
Offline Andrew L
« Reply #26 on: November 05, 2012, 10:52:35 pm »
If it aint broke fork around with it anyway is my moto. :)
Offline Andrew L
« Reply #27 on: December 13, 2012, 08:35:12 am »
is it broke yet
« Reply #28 on: December 13, 2012, 10:07:56 am »
Do they have electronic smoke in the box??? ???
Offline mitch75
  • Newcastle NSW
« Reply #29 on: December 23, 2012, 01:35:44 pm »
After seeing this post and sick of the kick back from my DT 360 I ordered one of the pulserless CDI boxes.
I have hooked it up and the news is all good starts easy and sounds more lively. ;D
I have not had the chance to ride it yet and see if the flat spot has gone.
Need to spend a bit more time in the shed and less at work.
Yamaha DT360a DT250b DT100c YZ400D WR250ZG.
