Author Topic: Methanol Vs Fuel tank leak putty  (Read 1941 times)
Offline Stewart Allen
« on: September 04, 2012, 09:18:07 pm »
Does anyone know if fuel tank putty will work with Methanol ? Or is there a particular brand or type that has worked for you with methanol.
Any help greatly appreciated.
Cheers Stewart
CHEERS STEWART
Doing it to old things is fun
# 74 Heaven
IT490 Will be going one day soon
CR125M
SL175 bitza
IT250D needs work
CR250RE Not going as yet
YZ125F
Offline matcho mick
    • Moto Tumbi
Re: Methanol Vs Fuel tank leak putty
« Reply #1 on: September 05, 2012, 08:35:10 pm »
what sorta tank,glass,steel,or alu?,figuring as long as putty is allowed to cure,before refill,can't see a problem,just make sure it's a good seal repair,joint integrity??,good luck, :P
« Reply #2 on: September 05, 2012, 09:43:24 pm »
Hi Mick,
           yeah I was a bit light on detail. CR125M Steel tank, put some fuel tank repair putty (some kind of erpoxy) on it tonight after grinding, wire buffing & cleaning with acetone. Had a 1 Hr cure, I gave it 2.5 Hr's and looks to have worked. Will recheck in the AM should be all go for CD9.
Stewart
CHEERS STEWART
# 74 Heaven
CR125M
SL175 bitza
IT250D needs work
YZ125F
