Author Topic: Coolant in crankcase  (Read 1238 times)
lc4
« on: August 27, 2012, 10:08:49 pm »
My son trying to do the right thing has had a go at repalcing the top end on his Husky 125 while I`m away on holiday, on my return (two weeks later) he asks for a hand to re-assemble it and to my horror find that he did not drain the coolant out before removing the cylinder, you guessed it, crank is half full of coolant :o
Now the thing is that I cannot see any signs of rust and now think has the rust inhibitor in the coolant saved me needing to do a complete rebuild ???
Re: Coolant in crankcase
« Reply #1 on: August 28, 2012, 09:42:58 am »
couple of weeks should be recoverable - several good flushes?
Offline suzuki27
« Reply #2 on: August 29, 2012, 06:50:53 pm »
I reckon mop it all up then spray plenty of WD40 in and mop that up and then some gearbox oil, mop that up or tip it upside down for a couple of hours to drain off then put it back together.
lc4
« Reply #3 on: August 29, 2012, 08:46:28 pm »
Thanks for the advise gentlemen  ;)
