Author Topic: RM 125 B clutch basket  (Read 4018 times)
Offline Nipper
« on: August 20, 2012, 08:31:20 pm »
Hi, would anyone have a clutch basket to suit an RM 125 B they would like to sell? Cheers
Re: RM 125 B clutch basket
« Reply #1 on: August 21, 2012, 11:47:15 am »
Didnt we go through this one a while back ?
was the basket i put up no use ? cant remeber
Offline Nipper
« Reply #2 on: August 21, 2012, 02:51:18 pm »
I think you offered a clutch cover .I am after the clutch basket.
« Reply #3 on: August 21, 2012, 02:59:28 pm »
this is the things i have kicking around FK's what it is not sure its off anything i currently have here. $20 you can have all it  ( Xcept that plastic dipstick thing i used that a while ago  :D
« Last Edit: August 21, 2012, 03:03:12 pm by Freakshow »
TM BILL
« Reply #4 on: August 21, 2012, 03:31:43 pm »
That looks like RM 250N or T maybe PE dont think its 125
Offline Nipper
« Reply #5 on: August 21, 2012, 04:22:44 pm »
Thanks freaky for the offer. But I reckon TM Bill is right it looks too big for the 125. I like the price too so if you got a basket for the 125 i will happily pay 20 bucks for it. Cheers.
« Reply #6 on: August 21, 2012, 04:36:04 pm »
this and a few side covers is all i got post 75 suzuki IIRC
Offline D project
« Reply #7 on: August 21, 2012, 09:15:23 pm »
PM sent ;)
TM BILL
« Reply #8 on: August 25, 2012, 10:08:16 am »
Nipper did you get a basket ?
Offline Nipper
« Reply #9 on: August 25, 2012, 08:51:01 pm »
Yes thanks  Bill I have been fortunate enough to get a basket from here on the forum, D project was the man I can thank for that. I did get a basket locally here in south australia but when i went to fit the basket it had 63 teeth instead of 62 so it was a no go.
« Reply #10 on: September 08, 2012, 09:44:02 pm »
Would the A basket work/fit the B?  They both run 17t primary's, I would think that the distance between shafts would be the same, I guess the smaller (less teeth) B basket would raise the overall gearing yeh?  Make use of the longer stroke B & C engines.
TM BILL
« Reply #11 on: September 09, 2012, 07:32:14 am »
B motor compared to an A motor is a slug  ;) B is more rideble for wobblers but if you want to be on the gas get a A motor  :)
Offline Nipper
« Reply #12 on: September 09, 2012, 07:01:58 pm »
Aaah so I am rebuilding the right motor then Bill....
« Reply #13 on: September 09, 2012, 08:57:22 pm »
Ha ha, just raise the exhaust port 1mm and trim the piston skirt 2mm on the B model and you'll get the top end you so desire  :-)
Offline Nipper
« Reply #14 on: September 09, 2012, 10:19:39 pm »
Cheers John that is some food for thought.
