Author Topic: tm 250 fork seals  (Read 1572 times)
cocksprocket
tm 250 fork seals
« on: August 17, 2012, 10:36:05 pm »
hi all, i need to replace the fork seals in my 74 tm 250, do i have to undo the nut on the inside of the forks at the bottom or do i just pull the slider from the bottom half...silly question to some, this is my first older bike!!  any help greatly appreciated.
Offline Doc
Re: tm 250 fork seals
« Reply #1 on: August 18, 2012, 08:16:08 am »
Yep, you need to undo that allen bolt ( I assume this is what you mean when you say nut?) on the inside at the bottom. Drain the oil first. Undo the screw using a suitable allen key then slide the fork lower off. A rattle gun is prefered as the screws are (should always be) installed with a locking compound which can some times cause the screw to spin the inner damping rod. If you don't have a rattle gun then find a suitable hammer to hit the allen key and loosen the screw with a sharp shock.
cocksprocket
« Reply #2 on: August 18, 2012, 06:16:48 pm »
cheers!!
