Author Topic: 1984 Husqvarna TE510 Engine Oil Capacity  (Read 3337 times)
Harro813
« on: August 12, 2012, 02:25:05 pm »
Hi, does anyone have the exact quantity of 4T oil required when changing oil on a 84 510TE? I have specs from a later TE510 which I've been using but last ride the bike started dumping oil into the stator cover. I'm hoping it's due to too much oil but most likely a main seal is failing!
Offline PEZBerq
  • Brisbane
Re: 1984 Husqvarna TE510 Engine Oil Capacity
« Reply #1 on: August 12, 2012, 06:20:04 pm »
1700 ml for the TX so I would think the same for the TE. Quaker State SAE 40 recommended in the spec sheet out of interest! Sounds like a seal to me. Check the oil reed is not stuck closed. Good luck
Offline Barronvmx
« Reply #2 on: August 13, 2012, 09:05:41 am »
The specification sheet I have for my 83 TX is 1.8 litres and 10W 40. I change the oil every meeting or at least every 2nd meeting depending how hard its treated. Make sure the filtter located half way on the barrel is clean as it is for the topend lubrication. Oil is cheap 510 husky parts are expensive.
Pm me if you need more info.
Huskies
CR250 1972, CR400 1972, SC125 1973, CR250 1975GP, WR250 1979/80, XC125 1983, TX510 1983, XC125 1984 project, CR250 1984 project
Honda's
SL100 1971, XL100 1974, Hondasaki 210, XL185 1981 project
Jawa's
1959 250 project, 1969 175 trail boss project.
Sachs 1969 125
