Author Topic: 78 / 79 CR 250 forks  (Read 1574 times)
TM BILL
« on: August 03, 2012, 05:47:49 am »
I have a 78 /79 CR 250 currently fitted with Simons forks , the Simons are coming off for another (probably never to be finished project  ::) ) so i need to fit somthing in their place .
I have a set of std forks for the bike but thet are as skinny as Nicole Ritche , is there somthing else thats better i can bolt in without too much drama ???
Thanks Bill
Re: 78 / 79 CR 250 forks
« Reply #1 on: August 03, 2012, 06:41:22 am »
The std forks are 37mm and aren't much good, you could use a 43mm cr480 front end or you could bore the clamps to 38mm and use 82/83 cr125 forks but neither forks are evo legal in Oz.
Or you could bore the clamps and fit 38mm 79/80 YZ forks and front wheel..
