Author Topic: UNITED ron100 fuel  (Read 3661 times)
Offline Sorelegs11
UNITED ron100 fuel
« on: July 22, 2012, 12:06:49 pm »
Has anybody had any issues with United 100 petrol?
Saw an item on MA site and got hold of some, mixed at 30-1 semi syn oil and 5 laps of DT the yz400d nipped up  >:(.
A strip down discovered a peice missing from the top of the piston at the exhaust and seiure marksp at piston sides.
I have since heard a few negative comments but some good ones. ???
Or is it not compatable with 2 stroke oil?
Offline southnztim
Re: UNITED ron100 fuel
« Reply #1 on: July 22, 2012, 01:38:44 pm »
I wonder if the oil separated from the fuel. Some oils seem to & others don't. Try mixing and then leave it sitting for a while. Should soon see. If it is a problem, try adding about 3 percent acetone. Sorts it out. Cheers, Tim
Offline Noel
« Reply #2 on: July 22, 2012, 01:48:45 pm »
Did you re jet,
united 100 has 10% ethanol in it ,
ethanol a bit like Methanol requires more fuel to air ratio?
Noel
Offline matcho mick
    • Moto Tumbi
« Reply #3 on: July 22, 2012, 08:42:14 pm »
that will teach you to mix your drinks  ;D, :P
« Reply #4 on: July 22, 2012, 11:43:05 pm »
Works a treat, makes more HP than ost race fuels when you tune for it.
Offline Graeme M
  • Administrator
  • Canberra, Australia
« Reply #5 on: July 23, 2012, 06:28:52 am »
So you have to jet up for it? 10%? 20%? Haven't tried it yet but would like to.
« Reply #6 on: July 23, 2012, 06:53:56 am »
Haven't touched a jet...................................... ;)
Offline Sorelegs11
« Reply #7 on: July 23, 2012, 06:26:10 pm »
 I went up from 360 to 400 main, but did not touch intermediate.
2 stroke or 4 stroke Lozza?
You are right Mick, I think I will stick to the cheap stuff  ;D
« Reply #8 on: July 23, 2012, 07:30:23 pm »
Run it in my car even and only deal with 2T bikes and karts(and chainsaws)
