Marque Remarks
Honda
What is that silver electric bit
Topic: What is that silver electric bit (Read 4883 times)
utsman
C-Grade
April 06, 2008, 04:41:58 pm »
What be it
bolted to my coil. Is it for lights?
utsman
C-Grade
Re: What is that silver electric bit
April 06, 2008, 04:42:45 pm »
It's on my CR500
LWC82PE
Superstar
April 06, 2008, 04:46:28 pm »
i would say its a AC regulator for lights. has it only got that 1 yellow wire?
utsman
C-Grade
April 06, 2008, 05:05:43 pm »
Yep
The yellow splits into 2 greens. One goes back to the subframe with a plug on the end, the other goes into a tapep up mess where one wire emerges and goes to the stator, and others are just plugged nowhere. Sounds like it's wired for lights eh.
utsman
C-Grade
Reply #4 on:
April 06, 2008, 05:59:00 pm »
It's gone.
if anyone wants it let me know
stu
Tony T
Reply #5 on:
April 06, 2008, 06:13:19 pm »
Yep, looks like a voltage regulator to me.
pm sent.
LWC82PE
Superstar
Reply #6 on:
April 06, 2008, 06:16:23 pm »
you probably got a trick stator on it too then!
utsman
C-Grade
Reply #7 on:
April 06, 2008, 06:22:19 pm »
Whatcha meen LWC, by a trick stator.
Will I be right to just disconnect this regulator?
STU
Tony T
Reply #8 on:
April 06, 2008, 09:09:41 pm »
What it means is that as well as the pick up coil for the ignition, there would be a lighting coil.
As long as the output wire doesn't short out anywhere, it is fine to disconnect.
Marque Remarks
Honda
