Author Topic: KX500A 83 CDI AND OR STATOR STILL NEEDED  (Read 2158 times)
Offline ELC hunter
« on: July 15, 2012, 05:43:13 pm »
After KX500A  83 CDI unit and or stator to buy or lend need to hear motor running to see if any engine work is needed. Have stator, it seemed to ohm up ok but using 250 cdi and sparked only a couple of times and weak.Wiring colours are different as well so only using uneducated guess work.Some parts cross reference list say newer ones fit has any one tryed this,using later model parts.Or would you have use the whole set to get it to run?Any suggestions welcome.
« Last Edit: July 23, 2012, 07:05:26 pm by ELC hunter »
Offline Stan S
  • Ballarat Victoria
Re: KX500A 83 CDI AND OR STATOR
« Reply #1 on: July 15, 2012, 07:01:00 pm »
I have both off mine if you want to borrow them. PM me with your postal address if you would like to try them.
Stan.
Offline ELC hunter
Re: KX500A 83 CDI AND OR STATOR STILL NEEDED
« Reply #2 on: July 23, 2012, 07:08:21 pm »
Any one have experience in using late model parts, any ideas?
Offline Stevo17
« Reply #3 on: July 23, 2012, 07:44:26 pm »
Maybe send it all down to Small Coil Rewinds in Geelong and get them to test the whole lot. Thats what I did. There is also a new CDI on ebay at the moment.
http://www.ebay.com.au/itm/350440357613?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Offline ELC hunter
« Reply #5 on: August 06, 2012, 12:06:16 pm »
Thanks to all that helped me out,should be ok when some parts turn up.
