Author Topic: TM Footpegs  (Read 8054 times)
Offline Toolboy
TM Footpegs
« on: July 15, 2012, 05:18:30 pm »
Gday all,
A question for the TM owners:
What footpegs do you use that have the return spring???
The pegs on my TM400 are Std and the rules to race are they are to be fitted with a return spring????
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Re: TM Footpegs
« Reply #1 on: July 15, 2012, 06:49:46 pm »
I'm pretty sure that Les at VMX Unlimited has aftermarket big ones with a spring set up.
Offline brent j
Re: TM Footpegs
« Reply #2 on: July 15, 2012, 08:15:22 pm »
Depending on which year TM you have, PE footpegs and springs fit right on.
These work and replace the ones with the "pimples" on them, 73-74?
Simo63
Re: TM Footpegs
« Reply #3 on: July 15, 2012, 08:57:15 pm »
I used RM/PE type from the late 70's through to the mid 80's.  They fit straight on and with a little "knob" welded underneath the footpeg for the spring they look and work factory.
The only problem with these footpegs is that they are cast and therefore you can't weld wider footpegs onto them but I guess if you purchased wider pegs for the same model RM/PE's then they would also bolt on.
If you give me your email address I can take a picture and send it to you.
Re: TM Footpegs
« Reply #4 on: July 15, 2012, 09:55:25 pm »
Not entirely, they are cast steel not cast iron so they are weldable.
You wouldn’t want to put any weight on a cast iron footpeg
Re: TM Footpegs
« Reply #5 on: July 15, 2012, 10:02:12 pm »
Make our own TM footpegs and get the widener's from Ballards.  8)
Offline Viper65
Re: TM Footpegs
« Reply #6 on: July 15, 2012, 10:33:31 pm »
I know exactly what to do with those footpegs.  Have a look at this website and all your problems will be solved...
http://www.geoffmorrisconcepts.com/
Suzuki RM370B, RM400C, RM400N, RM250D, RM250K, PE250 (82), KTM 250GS (81), KTM350GS (88), XR600 x 2, RMZ450 x 2 (07 and 012), KTM250 EXC, Gas Gas 125 (08), Gas Gas 250 (10) Trials & TTR125 and XR80 (82)
Author of Scooter News
Offline Toolboy
Re: TM Footpegs
« Reply #7 on: July 16, 2012, 08:16:50 am »
Thanks for the info guys...
My TM is a 74 and i do have a RM400N who's pegs look like like they will fit.
(Same sort of mounting)
I will look into the PE/RM pegs and Les's website for the wider set.
Simo...my email address  [email protected]
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Simo63
Re: TM Footpegs
« Reply #8 on: July 16, 2012, 08:47:00 am »
Thanks Geoff.  I had one break on me a while ago and I thought it was cast iron but I now know better, thanks.
Offline Toolboy
Re: TM Footpegs
« Reply #9 on: July 16, 2012, 12:40:32 pm »
Is it mandatory to have the return spring pegs fitted?????
As the stock pegs do not have this???
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline Bamford#69
Re: TM Footpegs
« Reply #10 on: July 16, 2012, 03:25:33 pm »
Hi,
Read 2012 GCR's
Classic Motocross;
18.5.1.6  Pre 60
18.5.2.7  Pre 65
18.5.3.7  Pre 70
18.5.4.7  Pre 75
18.5.5.6  Pre 78
"Post Classic Motocross"
18.5.6.7  Evolution Class
18.5.7.5  Pre 85
   "Folding footpegs must be fitted"
  notice, it does not say  "Controlled by a return spring"
  ( as written in  GCR  12.8.5.1 (b))
« Last Edit: July 16, 2012, 03:34:44 pm by Bamford#69 »
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: TM Footpegs
« Reply #11 on: July 16, 2012, 03:33:38 pm »
Fit the early 80's RM/PE/DR pegs (I just welded a 8mm nut to the frame to retain the stock RM spring) the work perfect
Ban BLACK rims NOW
Offline Canam370
Re: TM Footpegs
« Reply #12 on: July 16, 2012, 03:35:52 pm »
Hi,
Read 2012 GCR's
Classic Motocross;
18.5.1.6  Pre 60
18.5.2.7  Pre 65
18.5.3.7  Pre 70
18.5.4.7  Pre 75
18.5.5.6  Pre 78
18.5.7.5  Pre 85
 :o Woohoo! Wheres the popcorn?  ;D
Re: TM Footpegs
« Reply #13 on: July 16, 2012, 04:20:27 pm »
So what are you saying  12.8.5.1 doesn't come into play.
Offline Toolboy
Re: TM Footpegs
« Reply #14 on: July 16, 2012, 04:51:46 pm »
So my Std pegs "which are folding" comply...unless some one wants to picky and says it needs a return spring???????????
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
