Author Topic: DT250 73 swing arm sleeves, bush  (Read 2314 times)
Offline Sorelegs11
« on: July 13, 2012, 05:54:10 pm »
I am in need of a swingarm sleeve for my 73 dt 250. the original has a centre peice and 2 outer steel bushes. The outer bushes are stuffed and need replacing. I am pretty sure that the later 1 peice items will do the job.
Re: DT250 73 swing arm sleeves, bush
« Reply #1 on: July 15, 2012, 09:53:26 pm »
ebay has them also in nylon. either work well,, come with new spacer bush too.  but the bolts are not easy to find if you have to cut the old ones out
Offline Sorelegs11
« Reply #2 on: July 19, 2012, 11:05:39 am »
Thanks for the info Freakshow, I managed to find a bolt NOS but the steel bushes-sleeves are rare.
Offline Dono113
« Reply #3 on: July 19, 2012, 01:17:33 pm »
Just came from Greg Ball Engineering and was speak to him about the DT1's and makes a brass bushe for the swing arms if Im not wrong or heard wrong. He's a Kirrawee, in Sydney though
1983 CR125R
2003 CRF450R
CB750K1
2005 YZ85
1969 TS 250
« Reply #4 on: July 19, 2012, 01:40:47 pm »
Dono fnd out how much he is charging for them, alos if there in that bronze oil as well
Offline Dono113
« Reply #5 on: July 20, 2012, 08:51:46 am »
No worries freaky, I'll give him a call today
1983 CR125R
2003 CRF450R
CB750K1
2005 YZ85
1969 TS 250
