Author Topic: Note to self....  (Read 3080 times)
Offline shortshifter
  • Sunshine Coast QLD
Note to self....
« on: July 11, 2012, 05:37:06 pm »
If your clutch is not working.....look at the parts manual....Sidepipe clutches have 3 friction plates and 2 pressure plates,not 4 and 3 like later models.....DOH! :P Everything is not entirely interchangeable between models as I previously thought.
Re: Note to self....
« Reply #1 on: July 11, 2012, 05:46:06 pm »
Hee hee, found my clutch had a mix of early & late plates in it a some stage, the sidepipe plates are 1.5mm thick & the later model plates are 1mm from memory
The clutch gets pretty heavy & doesn't release properly if you get things mixed up as you've found out
Simo63
« Reply #2 on: July 11, 2012, 05:58:54 pm »
So um Paul .. is a note to yourself like talking to yourself??  ;D
« Reply #3 on: July 12, 2012, 08:51:55 am »
Simo,yes sometimes at great length.Tony I was looking at both plates and luckily thought that the thicker ones would be better.I also noticed that the big plate that holds the clutch plates on is also slightly thicker than later ones.Live and learn.Seems to work beautifully now with a test ride up the road.
