Author Topic: fork oil level Rm 250 N  (Read 3311 times)
« on: April 05, 2008, 05:04:30 pm »
Have change the fork oil  as per book ( 432 cc) high level per tube , this to me is not enough .
Missing from my specifications is table 9 ....being measurement from top of tube to oil level  ::)
Is the meaurement 180mm????
Offline holeshot buddy
  • sunshine coast qld
Re: fork oil level Rm 250 N
« Reply #1 on: April 05, 2008, 06:04:13 pm »
150mm from top of fork to oil level collapsed will be in the ballpark ;)
follow me to first turn
Offline suzuki27
« Reply #2 on: April 06, 2008, 08:48:43 pm »
I used to run 10 or 15 W or mix for 12.5W oil. Make sure your springs are within wear/length limit etc. I used to run around 10psi-on my T model this was essential and they were designed to run with air-without they will sack out.The trouble is very few will reliable hold air these days due to worn bushes-non-replacable and cast into outer leg! Some people run XR 250/400 springs these days if you are keen to keep the standard legs-the 82 Z forks are still 38mm but designed to run with no air! Worth a thought.
« Reply #3 on: April 07, 2008, 03:20:27 pm »
Thanks for the tips  :)    presently running XR 250 springs ( 2 piece ) and find them a bit stiff.
                                  As the old jobs needed about 20 psi to bring em up to length  ::)
                                  Auto transfluid is in at the moment ( experimenting ) with dampening affect
Offline brent j
« Reply #4 on: April 11, 2008, 04:30:34 pm »
Oldfart,
Get hold of a pair of top out springs from a set of 38mm kayaba forks (same as you have) and put them above the XR springs. This will reduce the spring rate by about 2 lbs/in. Doesn't sound much but makes a big difference.
Give teh springs about 5mm preload.
If you have the spare cash get some YSS PD valves or Race-Tech cartridge emulators.
Brent
