Author Topic: Wanted 34mm yamaha inner tubes or complete forks ( alloy lowers )  (Read 1447 times)
after some usable 34mm yamaha forks 34mm tubes or complete with alloy lowers.
YEe i know i can get em OS but thought i would try here first
Offline vmxrider
Re: Wanted 34mm yamaha inner tubes or complete forks ( alloy lowers )
« Reply #1 on: June 22, 2012, 06:09:28 pm »
Not sure if this is any help freaky but years ago before ebay and the internet I needed a good pair of inners for my MX 250. Searched a few local wreckers and found a set of 34mm forks from a 650 yamaha. I'm not sure what model they were off but they were longer than MX forks and had disk brake lugs on lowers.
They were cheap enough so I bought them in the hope I could use them. Pulled them apart and found them very similar inside to the MX forks just longer. So cut about 3" off the bottom of the tubes and remachined the circlip groove and fitted the MX lowers.
Raced with them for about 10 years and only recently replaced the front end with XL 250 forks and wheel.
XS 650 fork tubes are available new from here http://www.mikesxs.net/products-19.html#products but I don't know what length they are.
« Reply #2 on: June 22, 2012, 10:23:38 pm »
I have some AG bike ones if that helps
« Reply #3 on: June 22, 2012, 10:35:36 pm »
cool link, been looking for new washer and ring clips. Tubes are prity cheap too, just need a deal on postage and cheaper than a rechrome.  nice one. thanks for that
« Reply #4 on: June 22, 2012, 10:35:55 pm »
think there 30mm ?
