Author Topic: high bend bars  (Read 12609 times)
Offline TonyB
high bend bars
« on: April 03, 2008, 07:39:01 pm »
who still makes the high bend handle bars like we used to have. I have had to use extenders but they come loose somtimes with alarming results.. Holeshot buddy have you got some straight bars for yz,s 250 465 1981 etc?
'Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways,totally worn out, shouting,  ' Holy sh!t... What a Ride!! ' '
Maico31
Re: high bend bars
« Reply #1 on: April 03, 2008, 07:48:31 pm »
Renthal make a vintage high bar, think i saw a set on one of brads bikes and Pro Taper make a KX high bar which is pretty good. I've got Jimmy Button Renthals on most of my bikes, they are higher than the average bars.
090
Re: high bend bars
« Reply #2 on: April 03, 2008, 09:30:58 pm »
I had to buy them from the US as they can't supply here.
Offline holeshot buddy
  • sunshine coast qld
Re: high bend bars
« Reply #3 on: April 03, 2008, 09:32:19 pm »
johns right pro taper make a kx high bend which is a good bar
you could put risers under it if you like as well ;D
they come in  black or titanium ;D
follow me to first turn
Offline TonyB
Re: high bend bars
« Reply #4 on: April 04, 2008, 07:03:25 am »
Thanks guys,I will look at the renthals, yes if I use the high bend with extenders then I could even break out the ol tassles and hang them at each end of the bars, mmm I might even start a craze amongst the kids,,,
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: high bend bars
« Reply #5 on: April 04, 2008, 11:48:40 am »
tassles?
just when i was starting to think you were an ok fella Tony?
but now i'm not so sure.
there was a thread a while back, i can't remember if it was the old forum or current where we talked about high rise bars mostly for the pre75 crop of bikes.
Don Newell can get them in chromed steel and i've recently discovered the good old steel "Eliminator" bars in what they call the MX-7 bend. 820mm wide with about a 120mm rise at around $40 bucks a pop. most bike shops can get them and they come in painted silver. spot on for pre-75.
"flat bickie"
Re: high bend bars
« Reply #6 on: April 04, 2008, 01:44:24 pm »
Tony,
Don't forget the cardboard in the back spokes.....although it might take you past 96db while in motion.
Offline yzhilly
  • Melbourne
Re: high bend bars
« Reply #7 on: April 04, 2008, 03:03:22 pm »
I use the Renthall Jimmy Button bars on all my bikes too .Nice and wide and high not many colour options but.
Viper #436
Offline TonyB
Re: high bend bars
« Reply #8 on: April 04, 2008, 04:29:25 pm »
Brenden I remember the first two things I did to my chopper bicycle was to pull the tassles off and clip on the o'l cardboard, I even used different lengths of cardboard to get different sounds...then we got arsy and started welding on lengths to the front forks and we ended up with choppers that looked like the classic chopper in easy rider (older wiser 16years olds did the welding for us which used to last a few days then 2 days bed rest with road rash) ;D
Offline BETRIC
Re: high bend bars
« Reply #9 on: April 04, 2008, 04:48:12 pm »
RENTHAL MAKE A VINTAGE HIGH BAR, I USE THEM ON ALL MY VMX BIKES, THEY ARE CALLED ENDURO PRO-BEND HIGH (SILVER)
P/N 613-01-S1-05  AVALIABLE THOUGH THE IMPORTER  CASSONS
DELTEK, 72 MINI TRAIL, 73/4 XR75, 77/78 XR75, DG MONOSHOCK FRAME XR75, REDLINE FRAME XR75, PK RACING MONOSHOCK FRAME XR75, JWRP XR FRAME, SL70K1, 81 CR80RB, TY80A/B, YZ80A/B/D, GT50/80A, GTMX80A, 73 GTMX, GT1, COOPER MX, COOPER ENDURO,MX360A,MX250B,YZ125X MX100, 72 XL250, TC100,TL125, TY250C,IT250J
Re: high bend bars
« Reply #10 on: April 04, 2008, 09:04:39 pm »
i got a set of the tallest renthals i could get from http://www.bandcexpress.co.uk/ they are the dakar or enduro high bend. they are excellent for vintage bikes. ive also got a set of jimmy buttons and the desert vintage bend but the dakar bend is just a little higher and wider than both of those
Offline NR555
Re: high bend bars
« Reply #11 on: April 05, 2008, 06:44:26 pm »
Look for Renthal 764 bend (Jimmy Button).  Easier to find if you know the bend number.
Offline fatboyracing
Re: high bend bars
« Reply #12 on: April 06, 2008, 06:34:43 am »
Hi Tony,
I have put Eliminator bars on all my vintage bikes they are very cheap at $35.00 and they match the high Yamaha bars that were on the yz c models etc.
Fatboy
Offline TonyB
Re: high bend bars
« Reply #13 on: April 06, 2008, 08:07:17 pm »
Fatboyracing where do you get the el cheapos? and what is the rise? I also can't find the renthal 764? Jimmu Button? I found the others and it looks as though 95mm was the highest rise of those mentioned,,
Offline vandy010
Re: high bend bars
« Reply #14 on: April 06, 2008, 08:29:27 pm »
Tony, fatboys eliminators sound like what i've got. eliminator MX-7
about 120mm rise 820 wide and i get em from moorooka yamaha
"flat bickie"
