Author Topic: homemade chain rollers.  (Read 2394 times)
Offline suzuki447
« on: June 15, 2012, 09:11:01 pm »
gday ,just thought someone mite be interested in some homemade chainrollers i ve just made up .got a few old skate board wheels off  my son .first cut sides off with hacksaw to width to suit your guide width.then smooth finish sides before fitting them with bolt.these still have bearings which are great ,these rollers are on all my bikes and they spin instead of wear from chain drag .they work well.
bikes in shed.74tm125,76,78,82rm125s,...82,83rm250s.80canam qualifier.80,83yz125s.86yz490.80it125.76it400.80pe175and250.79rm50.76xr75.2xpuch50 magnums.jawa speedway.72honcho 90.84xr200.87xr100.phew thats all.
Re: homemade chain rollers.
« Reply #1 on: June 15, 2012, 09:13:06 pm »
Offline suzuki447
« Reply #2 on: June 15, 2012, 09:29:29 pm »
hi geoff.mate make one in ten min .i made half a dozen .just cut thru wheel at same width as bearings put spacer on both sides and mount .the skate bearing has about 5 or6 mm hole so bolts up easy they just spin and dont wear out.great.don
Offline steve234
« Reply #3 on: June 15, 2012, 09:54:02 pm »
you can shape them with a grinder while they are still on the truck, easy.
Bultaco M106 Astro
Wanted: Dirt track bikes / parts / info
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
« Reply #4 on: June 16, 2012, 12:54:56 am »
Thanks to both for the info, skateboard wheel idea sounds great but ima lazy bastard. Geoff will get my 16 odd bucks for one of these  ;)
