Author Topic: I need a couple of spokes...  (Read 3886 times)
Doc
« on: March 31, 2008, 08:37:14 pm »
actually about 8 to be exact  :-\ 5 outers and 3 inners from any one of the following..none of which I have in stock except the 400 and that's what I need em' for :(
PE250B/C/N, RM250A/B/C/C2,RM370A/B, RM400C
they don't need to be new or even near new just so long as they are servicable.
I'll eventually replace the whole lot with a kit but for now I need to save my pennies for a coming event  8)
oh..please and thank you in advance for any leads or spokes  ;)
Offline gorby
Re: I need a couple of spokes...
« Reply #1 on: March 31, 2008, 11:34:48 pm »
front or rear Doc ?
« Reply #2 on: March 31, 2008, 11:36:37 pm »
Is a PE 250 front wheel that belonged to those forks at my brothes place in crestmead your more than welcome to Doc. Will be in the trailer with my bikes and crap
Doc
« Reply #3 on: April 01, 2008, 07:22:40 am »
whooops..rear wheel I meant!..thanks gorby  ;)
I'm going to have a look at DR500 and other I have here today..with spokes sold in kits only cross reference is limited but I'm sure there's other models out there that ran the same length on at least one side.
Doc
« Reply #4 on: April 01, 2008, 07:01:39 pm »
chasing a rear sprocket for one of the above list also..not as easy to find as the DR items  :P
« Reply #5 on: April 01, 2008, 08:44:30 pm »
Which hub are you running ? early or later model  .   The early model ran a Dr 400 hub = PE sprockets  ;)
Doc
« Reply #6 on: April 02, 2008, 07:48:11 pm »
bugger..it's DR500Z wheel Stew..I couldn't be that arsey!  :D
« Reply #7 on: April 02, 2008, 09:03:09 pm »
If you have no luck with spokes , let us know and I will bring a DR 400 complete rear up . Straight fit  :)
Doc
« Reply #8 on: April 03, 2008, 02:32:20 pm »
No worries Oldfart. I've converted the DR brake hub to suit the stock RM cable and pissed off my offending rod setup that was interfering with the kickstart for years ;) The DR wheel is by far a better thing than the RM wheel and rather than have probs have decided to retain it..not original but it looks and works better and all works well together..will do until such times as I restore the ol' girl and redo the original wheels. The pressure to locate affordable parts is off..thank God! ;) amazing how you make do with something for 10 years but then all of a sudden it isn't good enough  :D If it wasn't for CD5 she'd still be covered in dust..just needs a splash of paint and Bob's me uncle ::)
« Last Edit: April 03, 2008, 05:11:32 pm by Doc »
« Reply #9 on: April 06, 2008, 08:14:11 pm »
Doc Ebay item no 120175476053 may help too.
Offline Scunge
« Reply #10 on: September 10, 2008, 10:17:16 pm »
Hi Doc,
I have NOS spokes for the following
RM125A/B - front and rear
Nipples set for the Rm125A front spokes
Rear spokmes set for RM25C
Also have front and rear spokes set for the Rm400T in great condition but not NOS.
Regards
