Author Topic: RM 250 b almost done.  (Read 7802 times)
Offline Nipper
« on: May 26, 2012, 01:51:37 pm »
I need some decent shocks for the rear and then it is testing time.
Re: RM 250 b almost done.
« Reply #1 on: May 26, 2012, 02:08:56 pm »
That is grouse!!!  I wanted to build a 250B but the 125 came along.  What sort of shocks you going to get?  I'll need shocks too, I can't justify blowing big money on real good units; I may have to give a set of elcheapo Progressive shocks a go until I can scrape up the cash for some good ones.
« Reply #2 on: May 26, 2012, 02:41:00 pm »
Well done, its a credit to you  8)
Offline crs-and-rms
  • heaven 23
« Reply #3 on: May 26, 2012, 03:12:25 pm »
very nice i love the b model
« Reply #4 on: May 26, 2012, 05:15:18 pm »
looking good there ole mate - "Works Shocks" are quite cheap at the moment .
Offline Nipper
« Reply #5 on: May 27, 2012, 12:48:53 pm »
yes shocks are an issue John, I could spend a fortune on them but it still wont make any difference to where i finish...at the back of the field. some research needs to be done as to what will represent good value for money.
Offline suzuki27
« Reply #6 on: May 28, 2012, 07:58:48 pm »
Looks great Nipper. How does it go? Has to one of the best pre-78 motors around.
Spend what you can on shocks. If it doesn't improve your track position there is always your back to consider.
Offline BAHNZY
« Reply #7 on: May 28, 2012, 09:01:07 pm »
Out of interest, how (& where) did you procure the Pro-Form pipe/muffler combination.
Rod (BAHNZY) Bahn
Simo63
« Reply #8 on: May 28, 2012, 09:22:41 pm »
You can buy Proform pipes and mufflers from Les Richter at VMX Unlimited.  Website here: http://www.vmxunlimited.com/
« Last Edit: May 28, 2012, 09:24:51 pm by Simo63 »
Offline holeshot buddy
  • sunshine coast qld
« Reply #9 on: May 28, 2012, 09:46:01 pm »
be interesting to see how it goes with the pipe
very large you could fit the dimensions of standard
complete pipe in header :D
follow me to first turn
TM BILL
« Reply #10 on: May 29, 2012, 06:52:27 am »
Can thoroughly recomend a Geoff Morris pipe  :)
Fitted straight on and the bike runs better across the range  :)
Offline piney
« Reply #11 on: May 29, 2012, 08:42:27 am »
nice bike well done !!!!
like to see yur a fan of the green as well
i notice in the back ground yu'v got an RM with yellow fork bottoms. was wondering whate model that is as i have a set under my house and i'm not familia with yellow flavoured bikes
cheers piney
TM BILL
« Reply #12 on: May 29, 2012, 09:00:53 am »
Hi thanks for that  :) yes i like my green too and even a little bit of red in the shed  ;D That is a n RM125B fitted with aftermaket yellow fork skins . The 1983 RM D range came with the fork legs painted yellow from factory . They also have a lug with a hole in it, cast into the brake side fork leg to support the outer front brake cable , as the bottom 600mm of inner cable runs exposed .
Offline Nobby25
  • Could possibly fit other models?
« Reply #13 on: May 29, 2012, 04:32:59 pm »
Top looking B nipper  :)one of my faves as it was the first 250 and the first new bike I had back in the 70s
Nob
TM125L RM250N TC125L RL250M PE175T RM80C RMX250T ATC70 YZ80B?
Offline Nipper
« Reply #14 on: May 29, 2012, 09:04:01 pm »
Thanks for the feedback with the bike.I havent ridden it yet ,only run it in the shed and it  sounds great. Hey Bahnzy Simo hit the nail right on the head the pipe and muffler comes from Les Richters at VMX unlimited,realyy impressed with his service for all the parts I have purchased from him. The shocks I will spend as much as I can afford "works" seem like a good reliable brand ,but I will also contact Walter as he is not too far from where I live see what he has available too. TM Bill that is a real sweet looking pipe some great work has gone into the manufacture of that baby !
And where did you get the stickers for the TM 125 suzuki ? I reckon that "works " look is fantastic. I want to tart up my TM 125 and a new set of stickers would be just the ticket.
