Author Topic: Nice YZ  (Read 10909 times)
Re: Nice YZ
« Reply #15 on: May 25, 2012, 12:42:01 pm »
I shall not treat your reply with the contempt it deserves young Geoff  ;D
Come on now Ross
What say we give it a month or so, that should give you enough time to think up some sort of worthy retort
 ;D
albrid-3
Re: Nice YZ
« Reply #16 on: May 25, 2012, 01:09:14 pm »
Where was that shot taken of the YZA (Geoff)
Re: Nice YZ
« Reply #17 on: May 25, 2012, 01:58:21 pm »
It was taken at Campbelltown 2010 Dave
http://www.geoffmorrisconcepts.com/11/capturing-the-moment/
Re: Nice YZ
« Reply #18 on: May 25, 2012, 03:55:47 pm »
Geoff - I refuse to lower myself to your level - and 2 x valium have helped  ;D
YZBs had left hand pipes but the works bikes had the right hand pipe like the one above.  Can't remember the make out of the US, but a friend of mine bought one Freaky that goes down the RH side.  Can get the details if need be.
Re: Nice YZ
« Reply #19 on: May 25, 2012, 04:33:31 pm »
the way that one is up there is how the "A' run.  im confused what your calling left and right now.
Anyways the one up there is correctly routed and it looks like a Circle F.
Re: Nice YZ
« Reply #20 on: May 25, 2012, 04:34:39 pm »
sC4RUB THAT Its got a shit load of lobsta sections so its probally a  gmc
Re: Nice YZ
« Reply #21 on: May 25, 2012, 06:46:06 pm »
My Cheney has a Pro-Form YZ360A pipe which is on the right side as you can see. I think it's similar to the pipe in my original top shot of the white YZ360. I had to do some cutting and shutting to get it to fit through my central airbox 'tunnel' and out the right side instead of the original left.
« Last Edit: May 25, 2012, 07:05:55 pm by firko »
albrid-3
Re: Nice YZ
« Reply #22 on: May 25, 2012, 09:31:02 pm »
very nice job, I must say.
Re: Nice YZ
« Reply #23 on: May 26, 2012, 09:13:29 am »
Freaky - out of the motor the YZB's turn left, A's turn right.  There is an aftermarket pipe for the B that matches the A model pipe and doesn't come back across the motor.
Re: Nice YZ
« Reply #24 on: May 26, 2012, 02:50:16 pm »
Rosco do you know if they could make the pipe for the yzb but the motor to be a SC500 ? .
Re: Nice YZ
« Reply #25 on: May 26, 2012, 03:06:28 pm »
no I don't sorry.  I reckon for that you would have to speak to my arch nemesis Geoff?  :o
Re: Nice YZ
« Reply #26 on: May 26, 2012, 06:34:23 pm »
Speaking of SC 500’s I need to borrow one to build a pipe to so I can stop a NZ customer from harassing me.
Anyone in Vic with one please give me a call.
Re: Nice YZ
« Reply #27 on: May 26, 2012, 07:57:26 pm »
got one here in Tas if you need it Geoff
Iain
Re: Nice YZ
« Reply #28 on: May 26, 2012, 09:34:38 pm »
I have some sc500's here Geoff can loan you bike or a just a pipe it that helps.
Same frame as the MX 250/360  and so is the pipe, only differance is the pipe diamater its larger so you can jig directly of any MXA you can find.
« Last Edit: May 26, 2012, 09:36:57 pm by Freakshow »
Re: Nice YZ
« Reply #29 on: May 28, 2012, 07:11:12 pm »
Geoff that pipe you made for me YZ400 into a mx 250 a frame would be very close for the bends needed . Iain
